Radio and speaker replacement
I went thru other posts for a couple hours, but having trouble finding a definite answer to this. I am swapping out the HU for a single DIN Sony and I am also swapping out the front door speakers to some JL components with the adapter plate. Here are my questions:
1) I was planning to use the harness ROEM-VET1, however it states it keeps the factory amplified speakers. Will this work even though I am bypassing them?
2) Do I need to run new speaker wires for the front, or will I be able to just use the factory wiring?
3) The rear speakers should not need anything done because they are not amplified, correct?
4) I know that ROEM-VET1 and the XSVI-2004 are both available for a harness, however they both retain the factory amp'ed front speakers. Are there any other harnesses available if I do not plan on keeping them?
5) Any other tips on being able to accomplish this without alot of spicing?
Thanks for any assistance on this!
Sounds like you have a C5. You should be able to use the factory wiring if you're not adding an amp. Just use the wires going to the mid/tweet in each door as the input ro the new speakers. Not sure how good it s going to sound without an amp. Remember, the factory is an amplified 8" speaker. Add some sound deadening material while you're in there.
redneck2725 (08-01-2018)
