New Head unit - do I need to redo all speakers?
Hirohawa (08-28-2018)
Received 1,636 Likes
You need to purchase the XM tuner, and it attaches to the back of your head unit.
You can re-use the factory antenna. I did but I found the reception was still poor. If you want to try it you need to buy the Sirius/XM 10ft antenna extension and run it to the factory XM location above the rear drivers side wheel well.
https://www.amazon.com/gp/product/B00NJTO4CY/ref=oh_aui_search_detailpage?ie=UTF8&psc =1
https://www.amazon.com/gp/product/B00DMFAOA6/ref=oh_aui_search_detailpage?ie=UTF8&psc =1
When I bought my C6 in December I activated an XM trial on the stock Bose system. I found the quality just awful and didn't listen to it after a day or two and went back to streaming from my iPhone. So when I installed my 8201NEX I didn't bother installing the XM hardware. Then I started wondering. How have you found the sound quality of XM with the aftermarket setup?
Listening back to back - the app sounded a TON better than the over the air streaming. When my trials run out, I'm killing it and just keeping the app access.
Hirohawa (08-29-2018)
I finally decided to test XM. My other car (2017 Explorer Platinum) came with the trial.. even in a new car, it is awful. So I finally decided to test listening to a song on XM, then flipping to the app, where you can restart the song from the beginning.
I didn't even realize there was an XM app. Like I said total Newb. So if you use the app you don't need the hardware I assume?
Hirohawa (08-30-2018)
If I were to get an amp and Subwoofer would I need a Optima Yellow top or would a normal Red top work?
Or just as is - will a Red Top be OK with the new headunit and speakers.
