Where is XM Antenna 2013 C6 Covertible
I just repurchased my 2013 vert back from the guy I sold it to four years ago. I am putting Kenwood 575S in and have purchased the 10" extension cable but cant remember where factory XM unit is to hook the ext. cable to. I searched couldnt find location, I knew at one at one time but have forgot. Any help would be appreciated.
Thank you
Thank you
Received 1,636 Likes
Not sure about the vert, but in my coupe it was located above the driver's side rear wheel well.
It's mentioned in this thread, once again it's a coupe though,
https://www.corvetteforum.com/forums...is-to-diy.html
2010 vert here and yes behind the waterfall. I would think 2013 would be the same. Easy to get to and it is mounted on a metal bracket. I took mine out and mounted an aftermarket amp in this location on that bracket.
