According to the wiring diagrams available here, the left front speaker should be tan and gray, I have black w/ dk red stripe and black w/ dk green stripe. The black w/ dk red stripe has the small terminal, of course the black w dk green stripe has the large terminal. Which is the speaker (+), speaker (-)??
OR....please tell me where this info is. I have searched and could not find any info on these wire colors.
This is for the smaller speaker in the door Left Front Speaker Wire (+): Tan Left Front Speaker Wire (-): Gray Right Front Speaker Wire (+): Light Green Right Front Speaker Wire (-): Dark Green
That info I found, however my '04 does not have the tan and gray wire colors to the left small door speaker....that is my question.
I have read that BOSE speakers are reversed from everyone else so, if the Blk w/Dk Red has the small slide-on terminal size, that is the (+) side, then Blk w/ Dr Green should be (-).
Hope so anyways as I swapped the Blk w/Dk Red and Blk w/Dk Green wire terminals in the 8 terminal connector so I did not have to cut the slide-on terminals off.
