Sponsored by: Innova
Anyone Using Brown Bread Sound Deadener?
Old Feb 10, 2003 | 09:11 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Anyone Using Brown Bread Sound Deadener?
I am looking to do the inside of my convertible and looked at the website and was just wondering if anyone here is using brown bread sound deadener and what do you think of it. I will probably do the inside of the doors on my truck to try and quite it down some to help the sound.
What are some alternatives available?
http://www.b-quiet.com/brownbread.html
[Modified by Eddie 70, 9:12 AM 2/10/2003]
[Modified by Eddie 70, 7:03 PM 2/10/2003]
Old Feb 10, 2003 | 10:03 AM
gdh's Avatar
gdh
Default Re: Anyone Using Brown Bread Sound Deadener? (Eddie 70)
I will be using it as well as the b-cool heat barrier very soon. Have only read good things about these products on this forum.
Old Feb 10, 2003 | 02:59 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
I have used Brown-Bread on several occasions and it performs very well. You can buy 70 ft^ of it on ebay for a little over $100. You should be pleased with it. :thumbs:
Old Feb 10, 2003 | 03:49 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: Anyone Using Brown Bread Sound Deadener? (The^Nomad)
ebay would be the best place to get it from.
Old Feb 10, 2003 | 05:11 PM
'71vert's Avatar
'71vert
Looking at using this product also. Does anyone have an estimate on the amount needed for a C3 convertible? Probably end up just doing the rear and the doors. Will the 70 ft^2 be enough, too much?
Old Feb 10, 2003 | 05:39 PM
_Nomad_'s Avatar
_Nomad_
Default Re: Anyone Using Brown Bread Sound Deadener? ('71vert)
70 ft^ would be plenty. Do mulitple layers of it and try to do the floor pan as well. Even the firewall if you can, but that's up to you.
Old Feb 10, 2003 | 07:02 PM
Eddie 70's Avatar
Eddie 70
This is what I am gonna do to the 70 when I get to this point. I want to do the doors on my truck first.
Old Feb 11, 2003 | 10:48 AM
70PurpleLS7's Avatar
70PurpleLS7
a little over $100???? Look again, for 70 sq ft, it's $149.
Old Feb 11, 2003 | 10:58 AM
Kale's Avatar
Kale
Default Re: Anyone Using Brown Bread Sound Deadener? (70PurpleLS7)
Go with Edead
eDeadv260 1 60sq. ft. roll of eDead v.2 $70.00
Old Feb 11, 2003 | 11:51 AM
MHLY01's Avatar
MHLY01
Brown bread is good, I would also use Raamat, which is great stuff and cheap. Go to Elitecaraudio.com and search for Raamat. I use it on all our competition cars.
Old Feb 11, 2003 | 01:16 PM
M396 #00-011's Avatar
M396 #00-011
I have 175sqft in the Mallett. Brown Bread is really easy to use and form, even without a heatgun. Just use gloves, the little metal backing will slice up your hands!
Old Feb 11, 2003 | 01:56 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Re: Anyone Using Brown Bread Sound Deadener? (gdh)
I went to the website and don't see anything called b-cool.
I am looking for something like this to put over my trany line to reduce heat coming in the carbin.
Old Feb 11, 2003 | 02:09 PM
Kale's Avatar
Kale
Default Re: Anyone Using Brown Bread Sound Deadener? (mike76002)
I put some Frost King 1/8" open cell foam with foil backing in my car. It didn't do much for noise, but the car is noticably cooler by the tranny now.
Old Feb 11, 2003 | 04:24 PM
0Vette Stripes
Former Vendor
Default Re: Anyone Using Brown Bread Sound Deadener? (Kale)
Kale, where did you get the Frost King 1/8" open cell foam with foil backing?
Will the Dynamat Extreme fix that heat problemo :D ?
I got some Dynamat Extreme left.
Old Feb 11, 2003 | 04:59 PM
Kale's Avatar
Kale
Lowes.
Old Feb 11, 2003 | 11:09 PM
_Nomad_'s Avatar
_Nomad_
Then they went up on the price, I last got 70 ft^ of Brown-Bread off ebay not long ago for $109.00 including S & H.
:iagree: Yep, next to Brown-Bread I would recommend Raamat. It takes more layers to get the job done but it's really cheap and works well.
:iagree: Yes Brown-Bread does apply well although I would still recommend using a heat gun to install it. And by all means DO wear gloves, I learned that the hard way and had a few fingers band-aided because of it! :lol:
To Anyone Using Brown Bread Sound Deadener?
