FS: Accusump w Elec Valve
SOLD
I have a 3 Qt. Accusump which I used for (1) race after a rebuild.
I had it rebuilt because my old engine failed and was concerned about debris. It was rebuilt by Canton and they replaced the electric valve. I'm also including the oil filter adapter and a large amount of braided lines and fittings. (I had this unit mounted in the passenger seat and an oil cooler in the trunk). Basically you have everything you need for an install- you will just have to take the fittings off the lines and cut to length for your particular application.
I dry-sumped the motor right after that event so hence the reason I don't need it.
$300 plus shipping for everything. I'll try to get some pics up this weekend.
