FS: Howe ASA/GTA/GT2/Track Day car
Want to go fast?
Want to do it cheaper and safer than a Vette?
Well, here's your chance.
Price: $25,000
Howe ASA/GTA/GT2/Track Day car for Sale in BATAVIA, OH | RacingJunk Classifieds
Price: $25,000
For sale: Howe GTA, GT2, Track Day stock car
2016-2017 rebuild with many NASCAR parts. No expense has been spared. You will not find a nicer, better built stock car anywhere! This car is ready to race or to use as a fun, fast, and SAFE HPDE/Track Day car.
V8 Stock car series champion as campaigned by Tony Amico. Originally built by Bill Bembinster/Woody Wood (BEMCO) for the ASA series and converted for road racing after the end of the ASA series.
Howe perimiter (square) chassis. Howe front and rear clips.
Brand new “Upgraded LS-1” engine built 100% to GTA specs. Engine build info below.
Car weighs ~2,600 lbs with fuel (no driver)
New Hendrick Motorsports Jerico transmission built for Cup series w/roller bearing tail section. Recent rebuild Hurst Competition shifter.
Cambered rear end. Brand new Penske Racing 9 inch rear center section with cooler pump pulley
New QuarterMaster Pro 5.5 clutch
Mark Williams NASCAR driveshaft with Mark Williams yoke. 1350 Spicer U-joints
Freshly serviced AP brakes front and rear with provisions for AP or PFC rotors
New brake and clutch master cylinders
New Richardson Racing full containment HANS seat
Fresh rebuild RE Suspension Bilstein shocks/coils
20qt Roush Racing Oil tank with 3 110V heaters.
Carbon fiber overflow/vent can
New hubs/bearings/Seals-It axle seals
Carbon fiber dash with SPEK-Pro shift light/pit-speed tachometer and new Autometer Pro-Comp Ultra-Lite gages.
Carbon fiber main switch panel with Eaton Aerospace Mil Spec switches and BMRS wiring.
Recently serviced Woodward Power Steering rack with new power cylinder assembly
New Turn One Racing power steering pump and pulley
New ATL fuel cell and new dual fuel pumps in 2015
New custom PRC Radiator/oil cooler
New DeWitts electric fan
Penske Racing AERO wheels
Onboard Fire system
Coolbox/Coolsuit system
Helmet blower
SCCA Logbook included
Engine Build specs:
ASA LS1 block
Fresh GM 243 heads with new OEM GM valves
GM LS6 intake manifold
New GM throttle body/MAF
Callies Compstar rods
Mahle Powerpack pistons
ARP Main studs, rod bolts, and balancer bolt
Isky valve springs
Mahle/Clevite bearings throughout
New Melling high volume oil pump
Rebuilt Razor scavenge oil pump w/new gears and seals
New AC Delco Professional alternator
New GMPP water pump
New GM LS6 injectors
LS2 timing chain
Trick Flow timing chain dampener
New GM coils
Fel-Pro gaskets throughout
New Magnecor ASA wrap around plug wires with DEI Titanium boot protectors
Engine dyno sheet available to interested buyers
Too many new parts to list.
Comprehensive spares package available to include brake rotors/calipers/pads, body panels, wheels/tires, etc
This car is 100% turn key ready to go.
Pictures available at:
GTA For Sale by A W | Photobucket
More pictures/details available upon request
Onboard Fire system
Helmet blower
Engine Build specs:
ASA LS1 block
Isky valve springs
New GMPP water pump
LS2 timing chain
New GM coils
