FS: inTech 28 ft all aluminum lots extras
inTech 28 ft all aluminum SOLD
Product: 6000# Axle Trailers
Length: 28.00
Width: 8.50
Height: 7.5
Number of Axles: 2
Axle Type: 6000# Torsion Axles
Model #: BTA8528TA4
Chassis
- Full Perimeter Aluminum Frame - All-Tube Aluminum Construction
- Triple Tube A-Frame - Dexter Torsion Axles
- Electric Brakes - All Axles - Breakaway Battery Kit
- 7-Way Trailer Plug - 2 5/16" Ball Coupler
- Safety Chains w/ Storage Loop - 5000# Manual Jack
- 16" O/C Floor Crossmembers - 16" O/C Wall Studs
- 16" O/C Roof Studs - Smooth Aluminum Wheel Boxes
- Spread Axle Design w/ Individual Fenderettes - ST235/80R16 Nitro Filled Tires w/ Steel Wheels
Interior
- One-Piece Aluminum Subfloor Vapor Barrier - 3/4" Plywood Subfloor
- (2) 12V Dome Lights w/ Switch - (1) 12V Power Roof Vent w/ Switch
- 6.5' Interior Height - (4) 5000# Recessed D-Rings
- 4' Interior Beavertail
Exterior
- .030 Aluminum Skin - Screwless/Rivetless Aluminum Exterior
- One Piece Aluminum Roof - Arched & Trussed Walk-On Service Roof
- 3" Upper and Lower Rub Rail - LED Premium Clearance Lights
- LED Slimline Tail Lights - 24" ATP Stoneguard
- 36" 405 Series Entrance Door - FMVSS Premium Entrance Door Latch
- Color Matched Front Verticals - Rear Ramp Door w/ Gapless Continuous Hinge
- Aluminum Bar Locks - Rear Ramp Door - Rear Skid Plates
Selected Options:
1 each 28' iCon Package
Electrical Upgades
- (1) 15 Amp Exterior Recept - (2) 120V 500 Watt Quartz Halogen Lights
- (3) 15 Amp Interior Recepts - (3) 48" Fluourescent Lights - Recessed (3) LED Recessed 12V Lights
- 12V Battery & Box Wired - 12V Cutoff Switch
- 12V Fuse Panel - 3 Way Light Switch for Fluourescent Lights
- 50 Amp Electrical Service - 50 Amp Gen Prep w/ Transfer Switch
- 60 Amp Converter for 12V - Motorbase Plug & 25' Shore Cord
- Upgrade to Dual Brake Lights - Upgrade to Panel Lite Exterior Lights
Exterior Upgrades
- 40" x 36" 405 Series Generator Door - Aluminum Slide Out Step
- Awning Rail - Extended Tongue
- FMVSS Side Door Lock - Stainless Steel Rear Header
- Upgrade to .040 Exterior Aluminum Skin - Upgrade to 4" Upper & Lower Side Trim
- Upgrade to 48" 405 Series Door - Upgrade to 8' Interior Height
- Upgrade to Aluminum Wheels - Upgrade to Cast Corners w/ Stainless Steel Verticals & Radius
- Upgrade to Stainless Steel Paddle Latches
Interior Upgrades
- 8' Premium Aluminum L Shaped Lower Cabinet - 8' Premium Aluminum Upper Cabinet
- Add Roof Vent w/ Wire for Future AC - Extruded Aluminum Floor
- Extruded Aluminum Ramp - Gen Compartment in L Cabinet
- LED Light Under Upper Cabinet - One Piece Aluminum Transition Flap
- Screwless Aluminum Walls & Ceiling
1 each Add Rear Stabilizer Jacks - Pair - 5000# Crank Down
and boogie wheels
1 each Upgrade to 3500# Front Power Jack - Battery Included
1 each Spare ST235/80R16 on Steel Wheel
1 each Add 54" x 48" 405 Series Top Hinged Baggage Door (Escape)
1 each Add Window to Entry Door - Per Door
1 each Add 6' Aluminum Ramp Extensions w/ 5" Bumpers
1 each Add 12V Dome Light
12 feet Add E-Track - Surface Mounted / Ft. For Tire Racks
2 each Tire Rack - 6' Fold Up Wall Mounted
Includes Carpet on Wall Behind Rack
1 each Upgrade to 36" ATP Stoneguard
1 each Upgrade to Lowered Skirt w/ Reverse Beavertail Design - Tandem Axle
1 each Add Awning - 21' Dometic w/ Weathershield - 12V Power Awning- Includes Awning Cradle - Standard: Pewter Vinyl w/ Black Hardware
1 each In Floor Winch Box w/ Pulley - Angled Mount
1 each 5000# Winch w/ 2 Wireless Remote Controls
1 each Upgrade to 2-Tone Color w/ Stainless Steel Polished Diagonal
I used it for one race season 8 events. I have sold my race car so now it's time to let the trailer go. All in great shape as you can see by the pics.
It can be yours for SOLD....
INTEROIR pics to follow.....
Length: 28.00
Width: 8.50
Height: 7.5
Number of Axles: 2
Model #: BTA8528TA4
Chassis
Interior
Exterior
Selected Options:
Electrical Upgades
Exterior Upgrades
Interior Upgrades
and boogie wheels
