FS: Hardbar Hub Toe Plates Nearly New
SOLD SOLD SOLD I bought these a while back and used them once or twice on my C5 and BMW. Hardbar designed these to bolt to the hubs with wheels removed, control arms on jack stands, making it easy to access the tie rod ends for easy "dial in" adjustments, wheels off one time and you’re set. Of course you can also use them without the uprights placed against the tires like conventional toe plates. These are very well built and solid, uprights are 3/8" aluminum plate and the “Toe Plate” angle is 1/4" aluminum plate, aircraft grade 12pt attaching hardware. Just add two tape measures and you are good to go. These were around $200 new. $85 shipped CONUS. PM please.
