I have a set of front and rear Phoenix tow hooks for a C6 Z06 that have been on my car for a few years, but they have never been used. They are in very good shape, but do have some rock chips as would be expected. $200 plus shipping.
If you are willing to separate I'll take the front tow hook.
Chuck
I am not wanting to split them up at this point. Several people have PMed me offers, and the first to commit gets them. If the offers to buy them both fall through I will let you know.
These are pretty easy to install, but does take a little time. The rear attaches using the two bolts that hold the exhaust. This is a tight space, but it is only two bolts. To install the front hook you need to remove the front bumper, which isn’t a big deal...you simply remove the ~5 bolts on the top of the bumper, then remove the push pins holding the wheel well cover panel in place so you can access three nuts on either sides and then you remove a few bolts/ nuts under the bumper then lift the bumper up and forward to remove it. Once the bumper is off there is already one hole to mount the front hook, then you need to drill the second. None of this is hard work but it does take a few hours.
