FS: Alcon TA4 BBK Kit
Gasoline Addict
Alcon TA4 BBK Kit
I have a pair of used, freshly rebuilt, Alcon TA4 mono-block big brake calipers for sale. These are the same setup that was used on World Challenge cars. The calipers have titanium pistons with ventilated inserts. Come with fresh DTC70 pads that are 20mm thick. Also have 2 used sets of pads that are still usable. The kit includes used 355mm Coleman rotors rings and original hats. And another set of 'emergency' worn rotor rings can be thrown in too. Included are C5 mounting brackets. The hats use Coleman rotor rings. that run $217/each new (I have a document that specifies their dimensions for re-ordering purposes)
Each caliper alone is $2850 brand new, not including rings, hats, and pads.
Asking $1500 + shipping. Located in Minneapolis, MN.
C5ZEE06 (07-17-2018)
Gasoline Addict
Area sweep of the Alcon is 85% larger than stock Z06 front brakes. This, along with better clamping force, leads to better fade resistance and better braking performance.
LG uses Alcon brakes on their race cars... if it is good enough for them, will be perfect for anyone else. 😉
