FS: Moroso Catch Can / Breather Setup -10AN
SOLD!!!
Moroso 85468
LS specific bracket with clamp (mounts to passenger side head)
Vibrant -10AN fittings: 2x9 0*, 2x 45*, 1x 180*, 1x Straight
Vibrant -10AN alum bung weld on fitting with cap
Vibrant -10AN Push loc hose (several feet)
Kind of a cobbled together/DIY setup I had going. I had the can mounted to the passenger side head, with -10AN bungs on each valve cover, so the lines are appropriate for that setup, but can obviously be cut/used however you want to. It was on a C5 and I know the bracket is the same for the C6.
I apparently got a little overzealous on the clamp at some point, so it has an indendation on the side (would be covered up by the clamp once installed) See pic.. The can itself is basically bone dry, see picture below. Used for a few thousand miles. The car is supercharged now, so I ended up changing up the setup again.
Asking $100 shipped for everything.
SOLD!!!!
Moroso 85468
SOLD!!!!
sold
