LS2 oil pan on LS6> Pics
The Fbody pan is different and won't clear crossmember.
http://www.hotrodlane.cc/Oil%20pans/...asurments.html
C6 LS2 oil pan (has shallow rear sump) (kit with bolts/gasket) = 12581810
C6 LS2 oil pick-up screen (same used on LS6) = 12558750
C6 LS2 oil deflector (same as used on LS6/LS1) = 12558189
Should our friend install the new screen and deflector too?
Originally Posted by gmblack3
Thanks Teddy!!!
Originally Posted by see5
Did the swap with no surprises. The crossmember had to drop ~6" to get it done but windage tray and pickup tube are same as LS1 and dip stick bolts to block unlike my old to header bracket. Fits perfect.
I run it with ~6 quarts as the the C6 manual recommends the 1 quart overfill for track use. This reads accurately on stick.
I sure feel better and looking at inside of LS1/6 it is no wonder it washes out. That pan is so wide and flat--I bet 2 quarts could hide in one of the wings under side load.
Wouldn't a real race pan with traps be better than a LS2 pan?
Originally Posted by danswofford
So, you can swap pans without removing the engine? I've been thinking about installing a Canton road race pan but thought that I'd have to wait until I was planning on pulling the engine.
A Canton pan may be better, but the LS2 looks like it should contain oil for pickup much better than LS1 which is wide and flat.
Originally Posted by daveydc5
What are the chances of adapting the LS7 dry sump system to other LSx engines? Any show stoppers. Dry sump seems like the real solution.
If you are that motivated, a Accusump is a consideration.
--update--
I finally blew my LS1. Looks like the dreaded rod bolt stretch, so pan is going on LS2 stroker.
