Castrol SRF, and V710 question
I see the note about using one bottle of Castrol SRF all year and further that you just bleed the caliper not flush the system. That seems great, but does the open bottle not absorb too much moisture from the air once the bottle gets partially empty?
Second, I have seen many posts saying you can put the 18" 315 v710s on stock z06 rears. I run TT and have a stock suspension and stock rear brake ducts. Under heavy cornering, do you guys that run this combo get any rubbing on the fender or brake duct? I read all threads but couldn't find that exact combo question asked/answered.
Thanks!
Thanks!
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Yes. I have no idea how much it absorbs, but it will definately absorb moisture at a higher rate than sealed. I try to use an entire pint in a weekend for this reason. It's not expensive.
No idea about the second Q.
Thanks!
Thanks!
Au Eng,
I saw your post about SRF in one of the myriad of posts about brakes
That style of changing/flushing works alot better for me since I never have time to really get everything done.
How many pumps do you say it takes to bleed just the caliper?
if I may suggest never work too fast, make sure it is done right and safe.
Thanks provette67, knowing someone else has done it with no problems adds some peace or mind.
Also, about the SRF: Haven't had one single problem with brakes since switching to SRF and Wilwood H pads.
Location: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Originally Posted by provette67
I run the 315/18 setup on the rear of my"stock" Z06 no problems.Go have some fun
Originally Posted by AU N EGL
2 bottles of SRF will do. One to flush your system as you can not mix SRF with other brake fluids. then just bleed the calipers before each weekend.
I've always run Motul 600 so I'm trying to decide if the pain of "no mixing" and the expense of the SRF is worth it. Atleast with SRF an opened bottle isn't junk.
SRF IS compatible with other fluids, but any other fluid mixing with SRF will lower the BP accordingly.
I bled through about a container's worth for the first time, and then smaller bleeds thereafter.
Originally Posted by gkmccready
So the "no mixing" doesn't include when you first put the SRF into the system if you push SRF out to all the corners and then bleed everything? How can you tell when it's non-mixed SRF coming out at each corner?
Color change of the new fluid.
This stupid little voice in my head is saying "flush with super blue, then flush with SRF" ...
Er, yeah, but with only 2600 miles on my car I'm thinking that the fluid I push from up near the master cylinder is going to be looking pretty darn new. :-)
