First Track Day for a new C6 Coupe
Okay, C6 Z51 track day prep... it's been a while since I've done a track day...
I plan to run Motul 600 brake fluid. What am I forgetting? Heading up to Thunderhill on June 30th with TEAM Racing (http://www.team-racing.org/) for a simple one-day track event.
What tools and spares should I pack? I'm planning on just driving the car up with no support vehicle and I'm sure the trackbox won't fit, and it's loaded with crap for my RX-7s, anyway...
glen
- - Thanks Gary@Hardbar
- - Hardbar Harness Bar
- - Hardbar Lap Belt Mounts (x2)
- - JetPilot Harness (x2)
- - Thanks Randy@DRM
- - DRM Brake Ducts
- - Thanks Gene@FredBeans
- - Base caliper brackets
- - Thanks Dave@Northstar Automotive in Mountain View, CA
- - PFC01 Brake Pads
- - Alignment
- - Thanks SoloTime
- - Vinyl Numbers
- - Thanks Cheapskate (me!)
- - NAPA Brake Rotors
glen
For a one-day you're probably set.
I always bring extra brake fluid and oil, and any wrenches I need to perform the standard maintenance (i.e. 19mm for removing wheels, 10mm for bleed, a small hose etc. etc.). Tire guage and my little cig-lighter compressor (works great for adding a lb or two).
Now that I have a trailer I throw alot more tools and stuff in there just to be sure, including spare pads and rotors (but again, for a 1-day you don't need that).
The C6 is new enough to me I'm not sure what wrenches to bring "just in case" ... I keep hearing about Torx head bolts, though, so I suspect I should pack up a Txx set?
Bring a couple of folding chairs, cooler.lots of cold water, and speaking from breaking my z-51 coupe in at Hallet (turned 1k miles on first go around) I'd lower that back end, way to high. I say that because i parked my z-51 next to buddies C6 Z06 and although I've changed fenders to capture his look not price, his was lower at least an inch, then I remember the first ads from GM aboout that. That's my next move. Fun racing warranteed cars. My other is way modified and expensive to race.
By all means, lower the car, but also make sure you have it realigned after lowering so all your angles are correct.
My C6Z is rock solid at speed running at factory height.
Frank Gonzalez
The only two tools you really need to bring are a torque wrench ( for wheels 100 ft lbs) and a deep 19mm socket, plus a tire gage to check air pressure before each run.
That is torque, not torx.
the cars rake must be kept or the car does get unstable at higher speeds. As Frank mentioned above lower the car but make sure yhou have it realigned afrer lowering and all your angles and rake are correct.
glen
