do the ccw corsairs come in a size to fit stock c6 coupe?
CCW will build them however you like 'em... I called them about 18x10+19x11 and 18x10+18x11 ... you can run C6Z sized rubber on the former set... just call or email them.
glen
'06 coupe
glen
'06 coupe
Originally Posted by RMilla17
what size tires front and rear?
DH
Originally Posted by racewheel
18x10 front and 18x11 rear, toyo ra1's from a sizing standpoint have one of the better tire packages, 275 35 18 front and 305 35 18 rear
rears are still larger than the fronts so that'll be fine - I ran 265/35 - 295/35 all last year without any trouble. Only time you have to worry about AH/TC is when the rear is smaller than the front. Speedometer will be off 1.7%, but that inside the margine of error anyways so you won't know the difference
john
john
