Recommendations: Cordless Drill/Driver/Impact Wrench for Changing Wheels
First of all, I know nothing about these other than I've seen the used at the track but always forget about asking.
What should I get? I want something powerful enough to break the lugs loose, not just turn the lugs. Do they work like an impact wrench? Also can torque settings be used to tighten the wheels w/o a torque wrench?
I went to Sears but couldn't make sense on what to buy.
Bob
Bob
Former Vendor
Re: Recommendations: Cordless Drill/Driver/Impact Wrench for Changing Wheels (RFC)
snap-on make one, its pricey (380ish) but it will break them loose, it you spring for it get an extra battery.
Milwaukee Electric Tool offers an 18 volt cordless impact wrench. At about 300 foot pounds, it will easily break loose and remove lug nuts. You can buy an attachment that will automatically tighten the lug nuts to 100 ft/lb. Check out this link:
http://www.mytoolstore.com/
Received 8,927 Likes
Re: Recommendations: Cordless Drill/Driver/Impact Wrench for Changing Wheels (Morpheus)
If you can do without the cordless feature and take one that runs on 12VDC then you can get a kit from Summit Racing for only $50. The extra $300 that cordless kits cost can be used to make the car go faster.
Bill
Bill
I've been looking for an attachment that could get me the correct torque setting on my lugnuts. Can you give me more details? I looked on the site you mentioned, found info on the impact wrench but nothing on the attachment.
Re: Recommendations: Cordless Drill/Driver/Impact Wrench for Changing Wheels (BluFRC)
I don't think any type "impact" wrench should be used. I use a breaker bar to break the lugs loose, and then use a 9.6V makita (I have lots of batteries) to zip then on and off. I then torque them appropriately after getting the car back on the ground. The Makita will tighten them to around 20ft lb or so, enough to lower the car, but not enought to damage the nuts or studs.
Dave
Dave
Re: Recommendations: Cordless Drill/Driver/Impact Wrench for Changing Wheels (y2khardtop)
Even when I at home in the garage I break them loose with a breaker bar and your still have to do the final tighten with a torque wrench, so Dave's solution is what I would do.
I always use a 24" breaker bar to loosen the nuts. After the nut is loose it only takes about 5 seconds to remove one nut with the extension and socket. Then use a torque wrench to tighten. I always (ok, usually) leave the car jacked up and have someone hold the brake while I torque the nuts at 40, 60 100 ft. lbs.
I think overall there is not much of a time savings when you figure charging batteries, locating a power source, etc.
I really do not know the answer to this but it would seem to me that if you use an impact gun enough times it could round off the corners of the nuts.
Re: Recommendations: Cordless Drill/Driver/Impact Wrench for Changing Wheels (corvette dave)
Agree, spend the dough on a decent torque wrench, buy a <$100 drill & 19mm 1/2" drive deepwell socket and have at it. I have used Dave's method for years.
corvette dave, if you can "round off" a lugnut with the proper sized socket in an impact wrench, you gots real issues. :crazy:
Re: Recommendations: Cordless Drill/Driver/Impact Wrench for Changing Wheels (h rocks)
Re: Recommendations: Cordless Drill/Driver/Impact Wrench for Changing Wheels (DaveFromCleveland)
I picked up a 10mm drill chuck to 3/8" square drive adapter at Home Depot for around $3. It's made by Stanley. I have seen them at OSH as well.
BTW, I use a good old 4-way lug wrench to break the lug nuts loose and I think it's a piece of cake. And I'm not a buff guy by any means.
I was just going to mention that!
In the garage, I use a breaker bar (or impact if I have air tools already out) to break them free. If I'm doing it by hand, I just use the socket and extension to work the lugs on or off. When I'm using the impact to put them on, I set it to low. As everyone should, I always finish with the torque wrench.
put lugs back on if I've already got air tools out.
Out at the track, I often use a good old cross type lug wrench. They're very handy!
Mike :flag
Mike :flag
H Rocks,
All I was trying to say was that an impact gun by it's very nature hammers on the corners of the nuts. I did not say the nuts would be unusable.
I have been working on cars for 35 years and used them several times, but only if all else failed.
I would not use one to remove lug nuts unless a breaker bar or ratchet/socket would not work.
This one IS NOT cordless, but it is 12 volt impact wrench (I have one) available through Harbor Freight Tools on sale at $19.99. (regular price $39.99).
It comes with case and 4 socket sizes and 12 foot cord. Item number 36175-2RNB. Harbor Freight is at: 1-800-423-2567. This is from catalog #734-J/Fall 2001.
The wrench delivers 200 ft-lbs. of torque, but can not be set at any desirable torque. Yeh, I paid $39.99 for mine!!!!
For those of you that don't absolutely need a cordless unit, this is a great buy. :D
Re: Recommendations: Cordless Drill/Driver/Impact Wrench for Changing Wheels (Jim 47)
Get a torque wrench and a speed wrench no batteries required always works :D
