T1 Sway Bars
Old 06-28-2007, 05:29 PM
frank dupuy
frank dupuy's Avatar
Default T1 Sway Bars
Can you mount the T1 sway bars on a C5 just using the GM metal end links or do they require the T1 end links?
Old 06-28-2007, 08:45 PM
ltborg
ltborg's Avatar
i believe you can you the metal end links but the plastic ones wont take the loads.
Old 06-28-2007, 09:08 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
As far as I know you can just fine... but you can't corner weight the car w/o adjustable endlinks to set the bar pre-load at 0.
Old 06-29-2007, 07:06 AM
Don O.
Don O.'s Avatar
Default T-1
You would be foolish to not use the adjustable end for these bars. More than likely by using the fixed end links you will be putting pre-load on them due to lowering and the variables in each car . MAKE sure you use the T-1 brackets too. If you reuse the stock brackets you WILL but the bars in a bind which again preload the suspension and make the car dangerous. They sell these bars as a KIT for a reason! My $.02.
Don
Old 06-29-2007, 08:43 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
If noise is a concern, use an OEM on one wide and a adjustable heim on the other. Still adjustable, but will cut noise in half.
Old 06-29-2007, 11:48 AM
frank dupuy
Thanks! Sounds like this should work for me.
Old 07-01-2007, 10:26 PM
GreyGT-C
GreyGT-C's Avatar
the holes in the T1 bars are slightly larger diameter than the bolt diameter of the stock links. They require a sleeve to be machined or they make LOTS of noise. I'm in the process of building a set of adjustable links for mine....
Old 07-03-2007, 10:27 PM
Pumba
Pumba's Avatar
The answer to your question is that you need to use the T1 end links with the T1 bars. Look at the picture below:
Also, if you install T1 bars with T1 bushing, you should install two flat washers under each bolt to prevent bar bind and excessive bushing noise.
To T1 Sway Bars
Quick Reply: T1 Sway Bars
