Ever see a wheel stud strip when removing the lug!?!? Hit it w/ a dye? Size?
Old 06-28-2007, 08:45 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default Ever see a wheel stud strip when removing the lug!?!? Hit it w/ a dye? Size?
Taking off my track wheels tonight one of the lugs didn't break free... after a feew turns it came loose, but in doing so it took a piece of stud w/ it an the inside of the lug is boogered up.
I'm at a loss... I always start my lugs by hand beofore running them on w/ the drill. Any clue how this happened?
Can I just go get a tap/dye and clean it up? What size do I need for OEM wheel studs?
Thanks,
Brian
Old 06-28-2007, 08:48 PM
varkwso
varkwso's Avatar
Thanks,
Brian
That is only a flesh wound it will clean up with a die no problem...
Old 06-28-2007, 08:49 PM
Cobra4B
Cobra4B's Avatar
^ Sweet... what size!
Old 06-28-2007, 08:56 PM
varkwso
varkwso's Avatar
That I do not remember - take a good lug nut find the tap that fits then buy the corresponding die
Old 06-28-2007, 09:07 PM
Cobra4B
Cobra4B's Avatar
^ Bah... that's too easy... anyone know
Old 06-28-2007, 09:20 PM
varkwso
varkwso's Avatar
I am pretty sure it is metric...
Old 06-28-2007, 09:29 PM
ErnieN85
ErnieN85's Avatar
Yes 12X 1.5
Old 06-28-2007, 09:56 PM
AMERICANMUSL
AMERICANMUSL's Avatar
Anti-seize!
Old 06-28-2007, 11:11 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
I would replace the stud. It is getting ready to fail and you were lucky to get it off without breaking it off in the lug nut. It hasn't anything to do with cross threading. After a certain number of times torquing the wheels down the stud threads start to fatigue and stretch. You get one last time tightening them and the lug nut seizes to the stud as the threads stretch and no longer quite match the threads in the lug nut. I just had this happen a month ago but my stud broke off in the nut. Over the years I have had it happen quite few times.
Bill
Old 06-29-2007, 12:12 AM
Cobra4B
Cobra4B's Avatar
^ How hard is it to replace the stud? Can't I drill holes somewhere so I don't have to remove the hub assembly?
Any tools to buy that will make pressing it in easy?
Thanks,
Brian
Old 06-29-2007, 12:19 AM
wallyman424
wallyman424's Avatar
Thanks,
Brian
you can drill holes in the back of the dust shield to get the studs out. i would recommend just taking it apart. it'll be much easier to work with.
to press it in, just get the harbor freight balljoint tool, and get creative with spacers (i used a pipewrench). removing the spindle and hub isnt too hard. the annoying part is finding a socket big enough for the axle nut.
Old 06-29-2007, 02:46 AM
BQuicksilver
BQuicksilver's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
It's not that tough to just remove the assembly Brian. Something like 8-10 bolts. The only tough one is the lower ball joint.
I used a socket + vise to push the stud out.
Old 06-29-2007, 05:54 AM
ScaryFast
ScaryFast's Avatar
Replacing studs is a snap - thread a lug nut on several threads then hammer the old one out. I have a C4 so no dust shields, but it sounds like all you need to do is expose the back of the nut. If you're tracking your car you ought to ditch the dust shields, anyway.
Stick the new one in and either press it in with a big-a$$ C-clamp and a 1/2" drive deep well socket, or simply stick the new stud through the hub, put a few washers over the front, and thread a lug nut on until the stud bottoms out. I've done it a million times that way at the track when I don't have many tools or much time.
And again, since you're tracking your car I'd get some hardened studs. Longer, too, if you're OK with how they look. You can get a set of ARP studs at any performance shop or online at Summit.
Old 06-29-2007, 06:52 AM
AU N EGL
AU N EGL's Avatar
ARP studs and hardened lug nuts
Old 06-29-2007, 07:31 AM
varkwso
varkwso's Avatar
And you can go ahead and do those bushings while you are in there...
Old 06-29-2007, 09:37 AM
Cobra4B
Cobra4B's Avatar
I think for now I'm just going to go get some spare oem wheel studs and replace the one.
I have a bad habbit of overdoing things... one boogered up stud will turn into all new studs, new lugs, poly bushings, and twin tubros.
Old 06-29-2007, 09:49 AM
DoingOK
DoingOK's Avatar
Cruise-In VIII Veteran
CI VIII Car Show Winner
wire brush studs.....very light coat of anti-sieze (LPS 1® Premium greaseless lubricant preferred).
Nix the twin turbos.
To Ever see a wheel stud strip when removing the lug!?!? Hit it w/ a dye? Size?
Old 06-29-2007, 11:09 AM
ScaryFast
ScaryFast's Avatar
At least get hardened studs. Replace them as they break. There's no reason not to. The cost difference is negligible, but you'll probably have to call around and find some.
Old 06-29-2007, 11:42 AM
Cobra4B
Cobra4B's Avatar
^ I'm going to see if the local speed shop has them... if not I'll order from summit.
Old 06-29-2007, 01:51 PM
2000BSME
2000BSME's Avatar
don't we all sometimes!? How many $1 problems have had $100 solutions in my vette ownership years I'll never admit.
Quick Reply: Ever see a wheel stud strip when removing the lug!?!? Hit it w/ a dye? Size?
