What racing jacks do you use?
I need a new floor jack, and I would like one that I can throw in the car for events. What jacks do you track guys use?
I would like it to be:
Lightweight (aluminum)
Low-profile
<$200
My buddy just got this Torin jack that pretty much fits my requirements, but I would like some extra input before purchase.
Low-profile
<$200
http://www.northerntool.com/webapp/w...3500_200313500
I love them because I hate using energy dragging and positioning the old jacks - these are just nice and easy. My husband has also started using one for Mustang wheel changes. They seem to be reliable - and if there's anything fun about changing wheels it''s using these jacks.
edit - and pepboys carried them so I checked them out there before buying.
BTW, if you mean "less than" $200, you need to use the <.
Although I only autocross , I swap my wheels for each event and was always dreading dragging out my husbands large/heavy jacks to lift my C4. Since I lift one side at a time, I bought 2 of the $70.00 torin jacks from northern tool and I'm glad I did.
I think it would be pretty easy to use, especially since I worry about raising one corner fully on my C4. I have heard people can crack the windshield or bend the car if not careful
Thanks for the edit, haven't been taking my math classes!
I picked up that jack from HF, on sale for $79. It's lightweight, works well, and seems to be fairly well made. For changing tires in the pits, bleeding brakes, etc., it's perfect. If you are doing tire changes on the fly or doing really heavy lifting, I'd go for something more durable, but for the regular stuff, it's more than fine.
We have the aluminum HF in the shop (I think it's a Torin) and use the JEG's aluminum jack at the track. I think that the JEG's is a much higher quality jack. If you're trying to lower the jack slowly, the JEG's works much better. The HF jack will release all at once unless you're really careful.
I think the JEG's is $129 plus shipping.
1 Post
Cruise-In II Veteran
My Pep boys aluninum jack failed, the Taiwan one I have works, but is falling apart, so I spent $550 on a CNC billet real NASCAR low profile jack made in North Carolina and it is worth every penny. I can actually talk to someone on the phone in my time zone! It weighs less, gets under anything and the handle comes off in a second and is shorter than most. Its is a 6 pump so there is more force required, but I prefer that in tight spaces.
cheapo harbor freight here too. they have 2 models, one with more lift than the other--I went with the higher one because I don't think jack stands would fit beneath the lower one. had mine for about 4 years no and no issues.
I have the HF one (not the super small one, the medium aluminum one) and a Craftsman partially aluminum one. I use the Craftsman at the track/autox because I feel better about dragging it around and getting beat up - it still looks and works like new. My HF definitely has wear and tear, I plan to replace it in the winter and donate the old one to one of the college students that autox with me.
St. Jude Donor '06-'07-'08-'09-'10
I have an AC Hydraulics DK20 low profile jack. It has a 3.1" minimum height and weighs in at 64.5lbs. Although not lightweight, it gets the job done. And it's made in Denmark to boot.
It was one of the only jacks that would fit under my car. I've used it for many thing over the past 3+ years and am very happy with it. Plus the price was right.
I use the smaller HF one for dragging to the track. I also have their aluminum jackstands, which aren't bad.
As you can probably tell, I don't trailer to the track yet.
I have a few. I use a small alum Sears in the trailer as it can be stored upright with out needing to be bleed. If I am racing the mustang I also have a 3 pump Magnum with me for the hot pits. I also have a Magnum 6 pump for the home garage and an old steel Sears (weighs around 80lbs). I have never owned a HF but have had the aluminum racing jacks for 10 or so years and they are great.
I would vote for a new or used aluminum 6 pump jack with a smallish round alum saddle. I use a hockey puck on the jack saddle. There are used ones out there.
Jeff
Jeff
We would go through one HF type jack it seems each season. So I picked up a torin 2.5 ton steel/aluminum jack 2 years ago for the garage (Northern and pep boys have them). 2 pistons, very smooth release, it has been a workhorse for a couple of years now. It is heavier at 60lbs, but feels much more sturdy.
