Stock seat with harness?
I was gonna upgrade the front brakes, but then remembered how much I slid around the last time on the track. Maybe I should look into harness/race seat first before tackling the brake mod. Is it OK to install a harness, and use it with the stock seat? I'm not sure how effective this is. For those who have racing seat/harness/harness bar, can you still use the stock seat belt? My car is not a dedicated track car at all, so being able to use the seat belt is a must.
Thanks for any input,
To start out you could just go buy some rubber tool box liner. Cut a piece to fit the bottom of your seat. and sit on it.
When you put your stock belt on, Real it all the way out, then let it retract. It will allow for a tighter fit.
PPl always ask where do START my mod?
answer: Contact patches.
Brake pads and brake fluid
Tires
Harness belts and seat
Tires
I added a lap belt and it made a huge difference as you can really cinch yourself down. I attached it with the rear seat track factory nuts. It's easy to use and also move out of the way. Both the lap belt and the factory belts can be used at the same time. A harness is nice and more secure but I wasn't ready to add the harness bar and a race seat.
--Dan
--Dan
--Dan
--Dan
You either need to do it right or don't do it at all. The 3 point is designed for you to fold over forward in case of an accident generating forward movement. Or in a rollover you either slide under the belt or fold over.
Adding harnesses to the stock seat isn't safe. What happens during a high speed head on collision. The belts not being adequately anchored on the seat. The belts will slide down the side of your seat and the forward motion will turn into downward motion and you can kiss your back goodbye.
I mean you can do it and it'll be easier to drive. But if you're looking for safety you have to do it right. Or you are better off with the 3pt system. More belts does not mean safer. I would seriously not go harness bar either. The corvette doesn't even have a back seat so you might as well get the roll bar. It adds chassis rigidity anyway.
All you need is a roll bar, a seat, and a harness. Find a seat that fits too.
Just my opinion.
Just my opinion.
St. Jude Donor '10-'11
One guy's approach ...
2004 ... DOT4 fluid
DRM brake ducts and phoenix spindle mounts.
2005 ...DOT4 fluid "turkey basting" begins for clutch (continuing)
2006 ... SS brake lines, titanium pad liners (reduce heat transfer to calipers)
Hawk HP+ pads
Amsoil synthetics in trans and diff
Valvoline synthetic blend in PS pump.
2007 ... Nitto 555 R2 tires for track (I still drive to track)
Carbotech XP 10/8 pads for track (HP+ now street/autoX pads)
'04 C5Z06 shocks.
4 pt weld-in roll bar
In-process - (before 19 Aug) DRM Ron Davis Radiator and integrated Engine Oil Cooler.
Planned - seats and harness (I'll retain the 3-pt belts for street)
Restraint (R3 or HANS)
Redline synthetic PS fluid
FWIW
Hawk HP+ pads
'04 C5Z06 shocks.
FWIW
I had a new Pyrotech belt laying around for years but what you're looking for is a bolt end lap belt like one here -- http://wescoperformance.stores.yahoo...cingbelts.html
--Dan
--Dan
I used a harness and a stock seat for a while. The harness was confined on the bar such that the ends were held close together, and thus even without the sport seats (I have a Z06) I found it pretty secure. It was never tested in a wreck, thank goodness. I'd have been toast. Harnesses are a touchy subject, but once I was using it on track, I couldn't go back. It's so nice to not be slung all over the place. Might not be as safe, but we're taking on a good bit of risk by being at the track.
I think it's important to recognize that harnesses are part of a system. The seat, the harness, the roll bar/cage and a head restraint all work together in a way that the stock belts can't to keep you together when you prang the car. If you have some of those elements but not all, some facet of your safety will be compromised. I'm getting that last element (head restraint) soon.
with a "race" the sides are up too high so the stock seat belt isn't against you hips like it should be, so you really need to swap back to your OEM seat when you're going to be using the 3-point and that only takes 5-10 minutes. Other than that, yes the 3-point and 5/6-point harness can both be in the car
seatbelt
Last autox I went to a fellow corvette racer had a sternum strap. I just went around the seat back and around your chest under the arms. He swears it works great. I think he wasn't using the stock seatbelt at all, just the strap. I was thinking of getting one. He goes by Talon95 on this board. You might want to PM him if interested.
Jeff
Thanks,
Hello,
Jeff
Jeff
The harnesses really must go through the seat back to be effective and anchor your upper body correctly. Sport seats are an option if you do not want to go to race seats. I took my seats tio a local upholstry shop and they did cutouts / harness pass throughs on the upper sections for $150.00. There is no support structure in that location and all they had to do was match the factory nmaterial and cut the foam. Only took a day and now the belts fit and work like they are supposed to.
That's good to know. I don't mind putting the race seat in for an HPDE day and swap back the stock seat for commuting to work, 5-10 minutes you said? Is there a particular brand of seat that's easier to install/uninstall than most others? I'll need to check out some seats in person though.
Thanks,
Thanks,
Give Garry Hoffman from Hardbar a call, he can set you up with everything you need, and it's easier to get everything from 1 source than to piece it together from 10 different companies like I did.
http://www.hardbarusa.com/hardbar/
He was just using the sternum strap for low speed autox. I didnt realize you were doing high speed stuff.
Jeff
Just my opinion.
Just my opinion.
