Cold PSI starting point for street tires?
While at the CGI HPDE 2 wks ago, "someone" told us (me & my 2 kids) to raise our cold street tire pressures by 4 lbs, which we did. This eventually resulted in high pressure warning on my DIC. This is contradictory to what I just read on turnfast.com. They recommend going with about 5 less PSI cold as a starting point. It's expected to be 80 deg F on Mon, and I'm running KDW-2s in Novice class. fwiw, my sons both have FWD cars. Any tips/recommendations?
I run the tire pressure that is recommended for the car. On my '01 Z it is 30/30 F/R. I have not had any issues with the way the car handles or the tires wear.. I run HPDE 3 with NASA-SE. I run the BF Goodrich KDWs in front and the KDW2s in the rear.
So, you're are 28/26 cold? Once they're hot, where do you like them?
Yup. Mid-high 30s seems to work pretty well for the Supercars. First day out in the new car I wasn't paying enough attention and got the stupid over-inflation warning... put a little extra wear on the middle of the tire that day.
I'll have better information next weekend since I finally ordered a pyrometer...
Last years setup liked 31.8 cold. It's going to change a lot, keep track of it.
I don't have pfadts, are those double or single adjustable? You'd probably want to start a new topic of that or try a search.
The recommendation to raise cold tire pressure by 4-6psi is meant for non-experienced road course racers in order to save the sidewall of the tires during the learning process. There's no sense in chewing up a good set of tires until you really know what you're doing anyway. More air in the tires obviously makes them more slippery. A newbie driving under these conditions will learn the limits of the car much sooner and be able to run quicker times once the aire pressure is lowered to improve traction.
hmm. that does maks sense, but my son
The "deal" is,
that I'd spring for this 1st one, since his bro recently ran over a pothole on the street and did the same thing. But, from now on, it's his mistake on his nickel! Of course, expendable items like brakes and tires will always be my responsibility.
