Store rotors vertical or flat ??
Old 08-18-2007, 03:48 PM
CHJ In Virginia
CHJ In Virginia's Avatar
Default Store rotors vertical or flat ??
I saw the post that NAPA had raised their prices on rotors. I cleaned out my local store and the warehouse that supplies it. Got two complete sets and one more set of fronts. They will last me the rest of this year and probably all next year. The question is = How do I store them ?? Lay them flat or stand them on edge ?? I do not want to end up with warped rotors. Your advice appreciated. Thanks !
Old 08-18-2007, 07:48 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
steel isn't fluid at room temp, so it shouldn't matter. However, if you are really anxious about it I would store them stacked flat on top of each other.
Old 08-18-2007, 11:03 PM
Gray Ghost GS
"AlohaC5" Senior Member
Gray Ghost GS's Avatar
If your wife doesn't mind - store them in your refrigerator freezer so you can use them as cryogenic treated rotors
Old 08-19-2007, 12:26 AM
Gary2KC5
Gary2KC5's Avatar
Originally Posted by AlohaC5
If you wife doesn't mind - store them in your refrigerator freezer so you can use them as cryogenic treated rotors
That's cold
Old 08-19-2007, 08:07 AM
davidfarmer
man, you must have a hell of a freezer!
Old 08-19-2007, 10:17 AM
rws.1
rws.1's Avatar
your choice....
they are stored flat and stacked in warehouses....
Old 08-19-2007, 03:10 PM
CHJ In Virginia
Well Mike -- I don't know about your wife, but if I tried that there would be hell to pay ! Somehow, I don't think that would be quite cold enough to do much good.
Old 08-19-2007, 03:32 PM
varkwso
varkwso's Avatar
try to keep them dry - but even if they get rusty they are fine to use.
They stack better in the horizontal plane (I have had them 15 high or so) - but cast iron does not flatspot as noted by Dave...so orientation is irrelevant...
Old 08-19-2007, 07:36 PM
Falcon
Falcon's Avatar
Send them over to my house, I'll keep them nice and tidy for you and they won't warp the way I store them.
Just call me when you need them back.
Old 08-19-2007, 08:15 PM
varkwso
varkwso's Avatar
Said the Walrus to the oysters.....
To Store rotors vertical or flat ??
Quick Reply: Store rotors vertical or flat ??
