Bump Stops?? Gone!!
Old 08-26-2007, 03:06 AM
Dirty Howie
Dirty Howie's Avatar
Default Bump Stops?? Gone!!
I have some Bilstein Sports that must be 3 years or 70K miles old with many track days.
Today while prepping the car for next weekend at WSIR I found that there were big broken and or missing rubber chunks under the plastic sleeve. There was a big washer loose and sitting on top of of one of the shocks. So I assume the thick rubber washer sits between the top of the shock body and this washer.
Is this the "bump stop" ????
Can I race with shocks in this condition ??? (they seem to work fine)
Is this normal for them to be destroyed like this ?????
DH
Old 08-26-2007, 06:34 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
yes mine were broken also.
Old 08-26-2007, 04:03 PM
Dirty Howie
John
I'm glad we both have broken rubber chunks in our shock sleeves
SO.....is it okay to run like this????? Please advise !!!!!!
DH
Old 08-26-2007, 05:48 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
They are a wear item, if you have blasted them out it means that a) you were bottoming out alot, and b) they were too soft. I do not know if the ends of the Bilsteins are removable so that they can be replaced but we have 3 different hardness and different lengths for the Penskes we sell. If you do not replace them and continue to pound them, the shocks and other suspension parts can/will be damaged.
Old 08-26-2007, 08:16 PM
Dirty Howie
Even if they cannot be slipped over the end ........ it seems that they could be cut in one place and then squeezed onto the shaft. I wonder if these are easily obtained??
I don't know how long Bilsteins should last but I think I'm gonna get a new set soon....
Old 08-26-2007, 09:15 PM
John Shiels
Get them rebuilt and revalved by Bilstien and it will handle better and not bottom out.
Old 08-27-2007, 12:04 AM
Dirty Howie
My car is also my DD so I can't have it down for as long as it would take for the turn around. Maybe I can just buy a revalved/rebuilt set from them. I take it from your comments that they can be made to work better than the off the shelf sets?????
DH
Old 08-27-2007, 07:49 PM
John Shiels
DH
Yes they do work better. If I was in your situation I would buy a used set of stockers real cheap and they send yours out. Usually takes about 7-10 days depending on work load they have. Do you have your stockers?
Old 08-27-2007, 08:04 PM
Dirty Howie
No my stockers were the fancy magnetic ride option, $1000 each shocks !!!!!!!!!!
DH
To Bump Stops?? Gone!!
Quick Reply: Bump Stops?? Gone!!
