Wheel Cannard ala C6 Z06...
Old 08-26-2007, 08:42 PM
Adam Boca
Adam Boca's Avatar
Location: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '07-'08
Default Wheel Cannard ala C6 Z06...
I decided to attempt to make the little front canards that are on the C6 Z06. After a couple attempts I got it looking right...
I am anxious to try them out on a track in 2 weeks to see if anything has changed...
Thoughts? (sorry for the dark shot, and the poor looking wheel wells, and the nasty drive way, etc...etc...etc...)
Adam Boca
Old 08-26-2007, 09:10 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
I have some I need to finish but they are much wider. How about a side view? Those don't look like canards to me from the picture, they seem to vertical. Are they just in the wheel well? I can't tell.
Old 08-26-2007, 09:12 PM
Adam Boca
Adam Boca's Avatar
I will get some better shots tomorrow, to dark now..
Adam
Old 08-26-2007, 09:16 PM
jtkeller
jtkeller's Avatar
St. Jude Donor '07
looks good - care to share how you did it?
Old 08-26-2007, 10:01 PM
Adam Boca
Adam Boca's Avatar
Yeah, not really canards, not sure what to call them...They are vertical pieces like on the Z06...
"lips on the leading edges of the wheel openings"
Adam
Old 08-26-2007, 10:02 PM
gkmccready
gkmccready's Avatar
http://forums.corvetteforum.com/show...1&postcount=73
http://forums.corvetteforum.com/show...1&postcount=78
Took a while to dig that up but I knew I'd seen it somewhere on the forum.
Old 08-26-2007, 10:08 PM
Adam Boca
Adam Boca's Avatar
I had not seen those posts, but I saw them on Rudy's car last year...
Adam
Old 08-26-2007, 10:26 PM
gkmccready
gkmccready's Avatar
Based on the discussion in the other thread-- what material did you end up using?
Old 08-26-2007, 11:15 PM
Adam Boca
Adam Boca's Avatar
I ended up using CF...
There is no movement in it as far as I can tell...
Adam
Old 08-26-2007, 11:19 PM
C6400hp
C6400hp's Avatar
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
Adam
Gurney flap/lip?
Old 08-26-2007, 11:20 PM
Adam Boca
Adam Boca's Avatar
Originally Posted by C6400hp
Gurney flap/lip?
ok, sounds good....lol..
Old 08-26-2007, 11:37 PM
joemoia
joemoia's Avatar
Gurney flap/lip?
They are called Gurney lips
Old 08-26-2007, 11:41 PM
Rob Willis
Rob Willis's Avatar
Any update on your spindle ducts Adam?
Old 08-27-2007, 06:02 AM
John Shiels
you can use a mulitude of materials it's not the space shuttle.
Old 08-27-2007, 07:14 AM
AU N EGL
AU N EGL's Avatar
The idea of the Gurney flap is to create a low pressure air zone on the out side of the wheel, to help pull or suck are though the wheel for added brake cooling. But if you dont have brake ducts for getting air into the rotor, the Gurney flaps may not serve their intended purpose.
But they do look great Adam
Old 08-27-2007, 07:23 AM
Adam Boca
Adam Boca's Avatar
I do have the DRM style ducts and a spindle duct by Quantum Motorsports...
Old 08-27-2007, 07:24 AM
Adam Boca
Adam Boca's Avatar
Far from my spindle ducts...I just test fitted them on my car..
I am not to sure...They are available by a company called Quantum Motorsports...Do a google search and call them up.
Great folks to deal with.
Adam
To Wheel Cannard ala C6 Z06...
Old 08-27-2007, 09:45 AM
KB Aero Biscuit
KB Aero Biscuit's Avatar
Actually, on the Z06 they have a triple purpose.
1. Help airflow around front tire to reduce drag.
2. Create low pressure to help evacuate engine compartment to reduce lift.
3. Add area to the front end for lift reduction.
Old 08-27-2007, 10:45 AM
Adam Boca
Adam Boca's Avatar
Do you think there will be any noticable difference with my lips? lol, sounds odd...
These are the same deminsions as the C6 Z ones..
Adam
Old 08-27-2007, 11:04 AM
KB Aero Biscuit
Adam
I refer to them as wheel house extensions. Gurney lip is the flange added to rear wings at the upper trailing edge that helps increase rear down force without adding much drag. Any differance? Depends on what your looking for. On the track where everything is optimized and you add them you might notice a difference on very high speed corners.
Quick Reply: Wheel Cannard ala C6 Z06...
