pfadt coilovers
Old 08-29-2007, 12:24 PM
samy segura
samy segura's Avatar
Default pfadt coilovers
I just installed my pfadt coilovers and camber kit (7 hours), set them up 8/8, does anyone has experience with those on the track, what adjustments are you suggesting?
Thanks.
Old 08-29-2007, 04:17 PM
jtkeller
jtkeller's Avatar
St. Jude Donor '07
I installed mine this past weekend as well - pfadt coilovers and sways - took about 7 hours as well. What a chore! I'm running 10/12 on the street, haven't had it to the track yet.
Old 08-29-2007, 08:29 PM
spankythegator
spankythegator's Avatar
I run the Pfadt coilovers on the track.....the setting really depends on the course but I run them 12/10 @ Sebring (fairly soft but the its a really bumpy course) and 14/12 at Homestead. I run the rear a click or two softer to add grip b/c my car tends to be loose. If you're loose: tighten front or loosen rear, push: loosen front or tighten rear. If you are set too stiff overall you will tend to skip in the turns and if you're too soft the car will be bad in left-right transitions/ esses etc. Hope this helps..remember, when starting out if the car isn't right make ONE big change and see what it does.
Old 08-29-2007, 08:34 PM
samy segura
Thansk a lot, for the input.
Old 08-29-2007, 08:36 PM
Quicksilver Z06
Quicksilver Z06's Avatar
I installed the CO's and Pfatty sways 6 months ago. For street I keep them 5/5 F/R. I've had 4 fun track days with them. Tried a few different settings, have found 10/9 works well. Both sways are one off stiffest.
Not sure if you read this on the Install and Road test:
http://www.digitalcorvettes.com/inde...racing-install
Also, am about 1.25 inches lower than stock, and running Nitto NT01's.
I am going to Homestead with NASA for 2 days this weekend and will be trying to fine tune it. I think these are awesome shocks for street and track and am very happy with this mod.
Old 08-29-2007, 09:25 PM
spankythegator
I'll see you at Homestead....unfortunately I'll be driving my friends miata which should be a 'fun experience'.....my car is prepped and ready to go up to MidOhio for nationals and Homestead is too close.
Old 08-29-2007, 10:39 PM
samy segura
well, I dialed-in 12/10, I'll be at big willow on saturday, I guess I'll have a better idea then about what to do. Thanks.
Old 08-30-2007, 11:48 PM
spankythegator
I almost forgot....make sure you set the rake and CORNER BALANCE that puppy. Made a HUGE difference.....I've got video (pre-corner balance) and the car was all over the place...would go from push to snap oversteer......a must if you're tracking the car
Old 08-31-2007, 07:55 AM
73-84 IMSA Widebody
73-84 IMSA Widebody's Avatar
Off topic
Hey Spanky... we are looking to move to Cape Coral this winter
David
Old 08-31-2007, 12:58 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I ran them at the recommended track settings, and they worked great on my lightweigh car (2950 with me in it). One thing to note: they suggest you adjust the ride height at the BASE of the threaded body, not on the big locknut screws. This is different from other coil-overs I've run, so keep it in mind. If you screw them out too much, of course they'll fall apart. Anyway, by adjusting them at the base, you actually change the length of the shock, and by adjusting at the coil, you adjust the ride height within the fixed range of the shock.
Nice setup...a bargain for the money!
Old 08-31-2007, 02:45 PM
samy segura
I did the corner balancing end up at 50.1% cross over, which is a 2lb off balancing, I think I can leave with that. caster 6.5 +/- camber 2.5 +/-, back camber 1 +/-. set the damper to 12/10. now I just have to learn to drive...
Old 09-01-2007, 11:00 PM
spankythegator
50.1....ohh that's awesome....she's dialed in...you're gonna love it!
Originally Posted by 73-84 IMSA Widebody
Off topic
David
Great! The weather and water is awesome.....and the housing market is going down down down....perfect buyers market...deals everywhere!
To pfadt coilovers
Quick Reply: pfadt coilovers
