Braking Distance with Hawk Pads
I'm trying to come up with a way of figuring out what my brake point should be at the end of a straight. I have an 02 Z06 with Hawk HPS pads. Say for example, I was able to get to 130 MPH on the straight and I wanted to make my turn in at 60 MPH how many feet of braking distance would it take to bleed off 70 MPH. Is there some rule of thumb, I realize there are a ton of variables like tires and driver skill. I also realize it's really all about practice and experience but I'm trying to come up with a starting point. I am interested in hearing which marker you guys lift and brake at.
HPS are STREET pads not track pads. So really about the same as your stock Z06 Pads.
Here is a StopTech White paper on Brakeing Systems ( PDF) This should get you started.
At a minimum I would switch to HP+ and preferably DCT70's. If you are talking about Grattan you have 100 ft increments on the left side at the end of the straight. With HP+ I would brake as I passed the first marker with the DCT70's I would wait to just before the second. After several runs the HP+ would start to need longer brake points or my speed was getting faster.
Received 8,924 Likes
There are a lot of variables besides brake pads. You have to contend with increased heat during the run, track layout, track conditions, tires, etc.
With near stock pads you will notice some loss of brake effectiveness as you get them really hot. If you braking going down hill you need more brake. The example you give is close to Turn 1 (The Ninety) at the Glen except the at the Glen you are on a pretty good down hill slope in the braking zone. Most people (with race pads) are on the brakes just before the 300 ft mark.
Bill
Bill
I don't know the source, but should make clear that I didn't come up with it
I like LG's version.
This has nothing to do with the OP's question of course. However, to that point, I think you have to experiment. Measure how long it takes you to brake, know what that is both in feet and in how it feels in your butt when the ABS kicks in. It'll be different for each pad you get too.
St. Jude Donor '10-'11
This is what I was going to say ... :-)
From the Au N Egl link ... under Kinematics " ... Note that this equation assumes a step-input deceleration from a fixed speed followed by
a linear and constant rate of deceleration until the vehicle comes to rest. In practical application, deceleration cannot be achieved instantaneously, nor can deceleration be assumed to be constant for the duration of a stopping event."
Stopping distance (or deceleration distance from speed X to speed Y) increases geometrically with speed.
I spent a whole session (about 12 laps) at Summit Pt practicing my braking points on HP + pads and stock tires going into Turn 1. Varied max speed into braking zone ... ranged from 120 - 130 ... and after the session ... thinking about it ... figured out that I really wasn't optimizing my deceleration rate ... so my braking points would need to be adjusted again once I improved my threshold braking technique ... so it's an iterative, learning process ... FWIW
The mathamatical approach is WAY to complicated, I scaned the "white paper" and got a head ache. I think I will just start to experiment, using the "later, deeper, harder" method.
x=vt+1/2at*t where v is drop in velocity, and t is time, and a is acceleration. you need to use v=at to determine the time it takes to declerate at the given braking load (say -1.2g), then substitute a and t back into the original equation.
Everything must be converted to like units, it f/s, f/s/s (32.2f/s/s = 1 g), etc
Freshman physics, but whether it's worth breaking out your calculator is up to you.
If it is important, build a spreadsheet that you simply input velocity change, and maximum decleration, and it does all of the conversion and calculations for you.
I was travelling out of state for a funeral when I did my calcs, and realize I made a mistake. The V in the x= equation must be the initial velocity (130) not the change in velocity (70)
Therefore, the time is still the same, but the distance changes to 369feet.
The distance is based on take the initial velocity component and subtracting the acceleration component, and I blew it.
Hope you didn't try this in the field, or you are probably in the tire wall right about now.
After that you have to experiment. The variables change every lap...pads heat up (and maybe get too hot), tires gain and then lose grip as they heat up/wear/age, track elevations affect where the weight is and the elevation/camber of the track may be slightly different if you're off-line, etc. Therefore you have to be able to make constant adjustments based on practical knowledge and feel.
JMO.
JMO, I totally agree with you...and it only takes me about 3 laps to get my braking points dialed in.
HOWEVER, as an engineer, when somebody asks, I can't help but try and answer. The math is simple, and while there are too many variable in the real world for it to be especially usefull, just knowing that braking distance is related to speed and speed squared (time squared, which you get from the v=at equation), it helps you realize how the energy dissipated and hardware damage goes up exponentially when you go faster.
btw, if you combine the 2 equations, you get
x= Vi * Vd/a - Vd*Vd/a/2
where Vi equals starting speed in f/s
Vd equals change in speed in f/s
a=accel in f/s/s
f/s =mph *5280/3600
f/s/s=g*32.2
a=accel in f/s/s
f/s =mph *5280/3600
f/s/s=g*32.2
