Bilstein sports or 04 Z06 shocks
hey guys I am looking to start upgrading the 03 Z06. I use the car as a DD and run a few autox's with it. I am planning on running 1 or 2 HPDE's next year as well. Anyone have any advise on shock upgrade? I have been seeing that alot of people are very happy with the 04 Z06 shocks. I am coming from running an 03 cobra for OT/autox so this is kind of different waters for me. I was very happy with my Bilstein's on the cobra.
Car is a stock 03 Z06 lowered 15mm on the stock bolts. (not quite all the way down)
Thanks guys!!
Thanks guys!!
St. Jude Donor '10-'11
MANY threads on this ... '04's, '06 ff Z shocks, Bilsteins ... and no definitive answer ... my take after reading all is that a car lowered more than stock bolts allow may be best on Bilsteins or '06Z or newer shocks, as they may be a bit shorter.
That said, on my street/autox/track time car lowered on stock bolts, I ended up putting '04 Z shocks on my '03 Z, as I felt they were most compatible with the Z06 spring rates and optimized for the Z. I'm happpy YMMV
You can find the full set of Bilstein Sport's for right at $300, it'll be hard to find the same price for '04Z shocks.
FWIW I went with the Bilstein Sports and couldn't be happier, the biggest difference I noticed was stability at speeds ot 100+
My 03 z06 is lowered 3/4 front and back and while my stock 03 shocks very rarely bottomed out (not nearly as much as a lot of people say they do) they were night and day difference better than the Bilsteins in handling and even straight line tracking.
On the freeway the car bounces more to the point its more annoying than a stiffer riding stock shock and it also lane wanders on slight curves, but I really prefer the more solid feel of the stock shocks better even though the ride is harsher.
For the past week I've been hitting the back road twisties and some fast straight line runs and I am no where near the same handling or speeds through turns. The car is loose and rolls a lot more through the turns. I guess I expected a much better comparison between the 2 shocks but in my opinion Bilsteins suck in comparision vs 03 C5 Z06 shocks.
I will be removing the Bilsteins in short order and go back to really enjoying back road twisties. I wouldnt recommend swapping Bilsteins for Z06 shocks at all.
I used the Bilstein sport shocks on my 03Z06. Car is lowered to the max on stock bolts and has a track alignment. I like the Bilsteins very much - car is rock solid at speed and through the turns. I would recommend them especially if they are cheaper than the 04 Z06 shocks.
Strongly recommend the Bilstein Sports. Briann510 - if yours are Bilstein sports, I'll take them off your ahnds so I can get a spare set rebuilt.
Bilstein Sports are approximately 1/2" shorter (piston centered) than the stock shocks, so, IMHO, preferable on your lowered car. We use them on our '99 FRC and they are great, but it is mostly a track car. We had an '04 Z06 before the '07 and I think the Bilsteins react better and more consistent under severe cornering than the factory '04 shocks, but that's just one opinion. As noted, the Bilsteins can be rebuilt and anyone who has tried this with the (Tom) Moracca valving will vote for that setup. Good luck.
This seems very odd. You think maybe you ended up getting the HD version Vs the sport? I know the stock 03 shocks should be better than the Bilstein HD's. Just a thought. I hate to hear you were dissapointed, everyone seems to be so happy with them on both track and street.
The problem now is through turns the inside rear tire is lifting and losing traction where as before it was solid and planted.
Yea part numbers were first thing I re-checked. I guess I have been so used to driving with stiffer shocks, maybe my driving style needs to adjust some. The Z06 shocks though are a lot stiffer compression and rebound and I could control the car easier.
The problem now is through turns the outside rear tire is lifting and losing traction where as before it was solid and planted.
I'm putting Sports on my FRC this weekend, and have only heard good things about them from those I trust.
Former Vendor
Randy
Former Vendor
This is very weird and very strange for the horrible change in handling. I think we sold you the shocks too. All you changed was the shocks? When the rear tire lifts, does it do it on both sides? or just one? Double check the swaybar too.
I will viewing this thread again!!!!!!
Randy
Brian,
Randy
Randy
Never on this road has the rear end ever started to wander coming round a turn or curve or the front react with understeer. I knew before hand the Bilsteins were not going to be as stiff a shock as stock Z06 ones and it was evident right awaywhen I bounced my weight on the fender after swapping them the Bilsteins weren't anywhere near as stiff as the stockers..
Now when I hit same curves and turns the car rolls noticeably more as each shock compresses more easily and rebounds easier and makes the car less stable pitching through the turns. Understandably on a curve or tight turn the car rolls a little more with softer shocks to one side thus lifting inner tires and weight off the ground more. I actually swung the rearend out a few times at xxx speed around a few turns which has never happened before but still maintaining control through it.
I guess after driving 35+ years SCCA, GT-1,2 AND 3 I'm just not used to a softer suspension setup and it will take some getting used to not being able to hammer as hard through the twisties as I'm used to.. I will eventually get coilovers or 12 way adjustables and the Bilsteins were just a shock in between the changeover.
Brian,
I think you've got a shock failure of some kind. I've compared Bilstein Sports vs. stock C5 shocks, Z51 shocks, and my current '04 Z06 shocks. The Sports and the Z06 shocks are very, very similar in stiffness, with the Sports maybe a bit stiffer, but definitely, absolutely, certainly, NOT softer.
HTH, and have a good one,
Mike
Mike
Brian,
Mike
Mike
I dont believe Bilsteins are advertised as being as stiff or stiffer than stock Z06 shocks.
Well.....Ill move on now and pass it on to the Mythbusters....
