Will Z06 Rear Wheel Fit On Front - C5
Has anyone tried a rear 18 x 10.5 Z06 wheel with a 315/35/18 tire on the front of their C5? Will it fit without spacers or fender modifications/rubbing?
I am considering a square 315/35/18 setup for ASP in auto-x and wanted to know if there are any problems or feedback?
I've run 305/35/18 RA-1 on a rear 18x10.5 on the front of my 01 Z06 - no problems at autox or track. Personally I would run the 315/35/17 though instead of the 18" setup. Cheaper, shorter, more common, etc.
Any feedback anyone has would be great!
7th Gear
i have run 18 x 10.5 in the front of my 02 Z-06 with 315 x 35x 18 v710s. It works quite well. You need to run 4-6 lbs more air in the front tires than the rears to keep the car neutral, though. Good luck
"AlohaC5" Senior Member
This combo has proven to be excellent on the track since CCW had the correct offset to ensure no rubbing. However, I wouldn't use this setup on the street/daily driving because there is 'some' limit in left and right travel - no impact on the track, some limits on the street if you need to make a tight turn. I run 275 front and 315 rear for the street. Mike
I've been running 18x10.5 speedlines with 315 Kumhos all around. Depending on how low your car is, the tire may scrub ever-so-slightly on the outside edge, but not enough to hurt the tire or fender. I find it a great combo.
