Michelin Pilot Racing Slicks
Old 06-14-2008, 10:17 AM
bowmanized
bowmanized's Avatar
Kyle your mailbox is full, but to answer your question...there are a lot more where those came from of the Michelin Pilot Racing Slicks.
Old 06-14-2008, 12:26 PM
blkz
blkz's Avatar
Mike ,is it possible to get in 325-345x19 or only 18" ? If so can you PM price of 295x18 and 325-345x 19 .Thanks, Walt
Old 06-14-2008, 01:30 PM
bowmanized
bowmanized's Avatar
Hey Walt,
At this point we carry 17" and 18" sizes.
Mike
Old 06-14-2008, 02:24 PM
blkz
blkz's Avatar
I need to find 18" all around. Do you know of any for the C6Z used and cheap?
Old 06-14-2008, 03:10 PM
bowmanized
bowmanized's Avatar
Not at the moment but I'll keep my eye out for us.
Old 06-14-2008, 04:39 PM
Joseesp
Support Corvetteforum!
Joseesp's Avatar
How do they compare to the Hoosier R6 and A6 in terms of grip?
How does the diameter compare to Hoosier A6 345/18? I ask because I ordered Goodyear slicks and could not use them since the diameter was 4" greater than the Hoosier. Such a difference in diameter throws off the electronics.
Thank you.
Old 06-14-2008, 06:44 PM
bowmanized
bowmanized's Avatar
Thank you.
The 27/65 Fronts are 650mm which is 25.6" just like the stock fronts. For the rear if you're using. The 30/65 is slightly bigger.
The 31/71 is bigger than stock in the rear by less than an inch but I don't have that information in front of me.
I have asked a ton of people about Hoosiers and Full Race Slicks and they seem to just laugh and say 'They make those for a reason'. But I've heard everything from 1 second a lap to 4 seconds a lap. I'll say somewhere in the middle 2 secs a lap.
Old 06-14-2008, 08:54 PM
blkz
blkz's Avatar
Thanks Mike ,please do ,I am interested .Walt
Old 06-15-2008, 07:44 PM
fatbillybob
fatbillybob's Avatar
Mike,
Can you post the available 17" and 18" customer slick sizes or pm a pdf file to fatbillybob@yahoo.com. also, if that file has a true measurement that would be great. For example 245 640 18 pirelli slicks are actually physically narrower than 245 640 18 hoosier ga/dp slicks. Sometimes if we are close to rubbing and that 1/4" or so really matters.
Old 06-16-2008, 11:53 AM
bowmanized
bowmanized's Avatar
Originally Posted by fatbillybob
Mike,
yes I will get more information as soon as I can. i do have a pdf file about the slicks. it discusses camber settings, tire temps and how they relate to each other. tire pressures too. 30 hot pressure is correct. i am having some connectivity issues right now so please feel free to give me a call. 9162614000
Old 06-16-2008, 01:28 PM
bowmanized
bowmanized's Avatar
Tire Size MSPN Description Diameter (mm) Tire Width (mm) Sec. Width (mm) on Rim (inches) Rvs./mile Rim Width (inches)
20/61/16 43302 Pilot SX S8A 606 mm 190 mm 211 on 7.5x16 852 7-8 in
23/62/16 41236 Pilot SX S8A 624 mm 233 mm 277 on 10x16 832 8-11 in
20/62/17 7359 Pilot SX S7A 625 mm 190 mm 220 on 8x17 819 7.5-8.5 in
24/64/17 98961 Pilot SX S8A 643 mm 220 mm 251 on 9x 17 798 8.5-10 in.
24/64/18 94021 Pilot SX S7A 643 mm 240 mm 252 on 9.5X18 798 9-10.5 in.
24/64/18 92284 Pilot SX Rain
27/65/18 82634 Pilot SX S7A 650 mm 270 mm 286 on 11x18 790 10.5-11.5 I
27/65/18 90216 Pilot SX Rain
27/65/18 81874 Pilot SX S8A
27/68/18 17843 Pilot SX S8A 682 mm 270 mm 317 on 12x18 752 11-12 in
27/68/18 76703 Pilot SX Rain
30/70/18 71949 Pilot SX S8A 703 mm 300 mm 352 on 13x18 730 12.5-13 in
30/70/18 96439 Pilot SX Rain
Here is the info. The 30/70s are discontinued and replaced with a 30/65 front and 31/71. The new tire technology has a taller rear tire to help absorb bumps and contain grip while utilizing more spring rates usually found on race cars.
Sorry about the format I'll clean it up when I have more time. I have to place some orders guys.
Thanks,
Mike
Old 06-19-2008, 12:23 PM
bowmanized
bowmanized's Avatar
NASA ST1 and TT guys can really make their mark with this setup.
Make your mark with Michelin Pilot Racing Slicks and Bowmanized today!
If you can win ST1 Nationals on these I'll give you $500 cash. Plus if you're using one of our shock packages you'll receive another $500.
Keep Digging
Mike @ Bowmanized
Old 07-07-2008, 01:15 PM
  #33
bowmanized
bowmanized's Avatar
One item I'd like to add. These are full racing tires and the bead is more difficult to seat than your average street tire. Therefore it CAN take more air pressure to seat the bead.
Also I've gotten some very good feedback regarding the Michelins as well. Thanks,
Mike
Old 07-09-2008, 04:00 PM
  #34
bowmanized
bowmanized's Avatar
Thanks Guys, these are going out first thing tomorrow.
Don't forget I have Hoosiers too for you DOT only rules guys.
Old 07-09-2008, 08:23 PM
  #35
RC45
RC45's Avatar
How do these Michelin slicks handle 100+ degree ambient temps?
Old 07-09-2008, 08:51 PM
  #36
bowmanized
bowmanized's Avatar
These are a full racing slick so they are hard to get up to temps in one or two laps. The hot temps will actually help these. Especially the mediums will work very well and last a long time. I've gotten some great feedback from customers already.
Old 07-15-2008, 11:09 AM
  #37
bowmanized
bowmanized's Avatar
Great results so far. A pro level racing tire for a reasonable price. Same tire most of the Z06Rs run in the FIA GT3 category.
To Michelin Pilot Racing Slicks
Old 07-19-2008, 11:58 PM
  #38
bowmanized
bowmanized's Avatar
Please consider the Michelin Pilot Sport Slicks for your next HPDE or Race.
Thanks,
Mike
Old 07-20-2008, 03:51 PM
  #39
AZ FASTEST
AZ FASTEST's Avatar
Order placed! Thanks Mike!
Old 07-20-2008, 10:03 PM
  #40
bowmanized
bowmanized's Avatar
Thank you very much for the order. Everything went through and these should go out tomorrow or Tuesday. I'll follow up with a tracking number and everything
Thanks for calling.
Please send me a pic of your car if you get a chance.
Quick Reply: Michelin Pilot Racing Slicks
