That does it...I'm buying a HANS. Quick question.
After reading about a fellow NASA member breaking his neck in 2 places in a somewhat minor accident last month at Summit (Story here), I'm buying a HANS. I'm looking at their model 20 Sport Series, but I'm not sure which tether style to get.
The choices are:
Fixed
fixed Quick Disconnect
Sliding
Excuse my stupidity, but I don't know which is the better option. I want to buy the one that is the easiest to deal with. Any advice is greatly appreciated.
The choices are:
Fixed
Sliding
Former Vendor
Scott,
The newest Hans inovation is the sliding tethers. This is what I have. It allows your head to turn side to side more. The quick disconnect is a nice feature because it makes the Hans easier to get on and off. As of now, the sliding tethers are not available with the quick disconnects, though I am told they will be out soon. I have gotten used to attaching the tethers now after the helmet is on, but it does take a little practice. Great device, glad I got one.
Robert
Robert
Sliding Tethers are the way to go. I debated and talked to a few people before I ended up doing the sliding tethers. The shop I bought mine from let me try all the different ones, Sliding tethers, fixed, quick disconnect, Pro and Sport Hans.
The sliding ones let you look ahead and down the corner better. It does take a couple of trys to get used to the connectors for your helmet but it's not that bad.
I believe the Hans will work with any SA2005 or newer helmet. Check their website.
Scott,
Robert
Robert
Money well spent
Frank
1 Post
Cruise-In II Veteran
I feel naked without it now. I don't have the sliding tethers but if I bought it now I probably would. Mark at MSI (a supporting vendor) is an authorized HANS vendor and is very knowledgable about trhese decisions.
there are many other choices as well.
The R3 device.
the new and improved R3, which I think is now called something else.
plus a few others on the market now.
They just mailed me a postcard with all their new devices.
The HANs is solely dependant on proper harness installation, while these other devices strap to your body.
The R3 device.
Takes about 15 minutes.
I'd get the sliding tethers if you can. For anything but the most hardcore applications they should be fine. The stock ones (like I have) are pretty restrictive on lateral head movement and take some getting used to.
The advantage of the QD is that in an emergency, it's easier to get the helmet off.
The advantage of the slider is that in the paddock and if you go off road, it's easier to see around you. for normal on-track it doesn't make a difference. even 180+ hairpins are no problem with the fixed tether, although it does just take a little getting used to.
1) not clear if he had a harness
2) HANS may not be effective in a lateral impact.
Former Vendor
The Hans sliding tethers can be attached to the older style device. Buy the sliding tether kit, around $100. Remove the fixed tethers and the sliding ones bolt on to any Hans device.
Most places that sell the HANS will install the studs for free or a very minimal charge. If you mail-order it, I'd still got to a local speed shop that is familiar with HANS and have them do it unless you are 100% certain you know what you are doing. Better safe than sorry. In that split second before you hit the wall, you don't want to be thinking "Gee, did I install the HANS studs and straps properly?"
Most places will give you a discount if you purchase the sliding tethers at the time of initial device purchase. At apexperformance.com the sliding tether kit is about $75, but purchased with the actual HANS I think it was only $15 extra. And they installed it.
I see no reason why you wouldn't modify a SA2000 helmet if that's what you have. It really does take 15 minutes. I checked and double checked mine for the reasons fasterisbetter mentioned, and it still only took half an hour.
