**one Piece Replacement C6z Pads For Oe Caliper From Lgmotorsports And Cobalt**
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Hi guys,
Cobalt Racing Brakes, a leader in race brake pad design, working with GM has now a one piece, larger brake pad for OE Z06 calipers.
Tired of the OE 'padlet' designed brake pads for your Z06? Cobalt has just finished their one piece replacement pads for your OE calipers. No modifications are required and these are a direct drop in replacement. More surface area gives you better stopping and longer pad life. Pad taper will also be reduced now as well.
Pricing is expected to be released later this week with compounds in both the GTS and XR2 material to be carried on the shelf.
Pads are shipping to us now, and I will have pictures as soon as they land.
Great news for open track guys!!
1 Post
Cruise-In II Veteran
Sounds like a good idea. The more pad volume (not just area) the better. I would really like to know the weight of one of these versus 3 of the padlets, that would give an idea of the relative % increase in pad. Any pics?
Former Vendor
Yep, retains all of the pins. If you have a stock car, and you have these pads, you need nothing but the tools to remove the old pads and put these in. No mods, no pin deletion, no nothing
Former Vendor
You are grip limited in the front with the tires as it is, but it was a GM requirement to leave ALL of the pins, which is fine with us.
More pins distributes the load more evenly across all of them, not one or 2 pins like other brands.
Interested in the price and avilability when they become available.
Maybe the ZR1 calipers will make a sensible upgrade down the line - as those are 1 piece pads out of the box right?
I was able to get the pins in and out for the fist season with high temp anti-seize before they simply stripped or siezed in place. I have pins that turn and won't come out and pins that are stuck and look like Micheal Jackson's face. They were just not made for more than about 4-5 brake pad changes at best and the soft nature of the metal turns them into worthless junk.
I just don't understand why PBR didn't design the calipers with traditional removal bridge. That would have made these calipers a real winner for how much they cost.
Not to put you on the spot Anthony, but how much?
I heard from another vendor that keeping all of the pins caused the pad to get "jammed" in place as it is energized by the rotor.
Regardless, I'm hoping this works out.
Are there any other brake setups on the market withguide pins through the center of the brake pad?
It would be interesting to know the results of any testing that was done with short "blank" pins in the center and only the end full guide pins in place.
