Road America Setup Help ...
Driving (6th HPDE) the Road America on 9/6-7 with my 06 C6 A6 and R6 slicks on OEM wheels.
What Camber (F & R) with Hardbar camber kit should I use? Any Toe?
Thanks.
Thanks.
You should always use a little bit of toe F and R to keep the car stable and to help on turns.
RA is all about speed, so I'd recommend just a little bit of toe out up front and the same amount in back. ...maybe about 1/8th total toe.
RA is primarily a turn right track so I'd say about -3 on the LF; -2.5 on RF; and about half those numbers on the back (depending on how good your bushings are).
Uh, take lots and lots of brakes!!!!!!
Former Vendor
I aggree with Chris on setup. Road America will eat up your brakes. I carry Cobalt Friction pads, in stock for your car. Unbelievable stopping power and will outlast any other race pad out there. Call me if you are interested, 630-844-0089.
Robert Finlayson
Performance AFX Motorsports
Robert Finlayson
Location: If you don't weigh in you don't wrestle Road America
I set-up a few cars for RA (since it's 15 miles away) and one thing that I do different than any other track is set the rear toe to 0, the only reason is because between the kink and turn 12 the track is a little curvy and your blasting through there at 110 - 140 mph and if you toe in the rear the car will be a little "darty" through there, it kind of depends on the driver some people don't mind it others want the car to feel planted underneath them.
Just a little tip.
Otherwise do everything everyone above said, epecially about the brakes.
I would look at upgrading your brakes to the XP12s Front and 10s Rear for Road America. You'll need it.
Former Vendor
Just a little tip.
