problem with nitto r2 tires?
recently Ive been on track and my car(C5) starts vibrating at 150+..could that be just a wheel balancing problem? car is fine any speed below that. I thought that it might actually be the tires since my other street tires didnt do any such thing at those speeds. this happens very briefly at the end of each straight.. it is annoying and vibrates my rear view mirror has anyone had this problem with these tires? maybe because they are more rigid? I hope it is just a wheel balancing thing.
I marked my Nittos once they were mounted and balanced and over the life of them they would slip on the rims from time to time. I know there is never anything i could do to street tires where the same could happen.
I would start there, but unless you want to have them balanced after each track day...I just lived with it once they were on.
This was after the first track day with them. I stopped paying attention to them after that. I also had one mounted on a Thursday, and then ran the next day and that moved quite a bit, maybe 6 inches on the rim.
1 Post
Happened to a car in our paddock this month at Road Atlanta. It was a detuned twin turbo Porsche (detuned to 700hp) normally 900. With monster brakes. If I didn't see it myself I would have said BS! But he had all 4 marked tire to valve stem. After our first run all 4 moved several inches. A lot of torque and brake power I guess stuff moves. He even had an adhesive on the bead! I would believe it could happen with our cars too! I just never looked.
I never had a problem with my Nitto's over 150. You're problem sounds like a balancing issue or an internal problem with the tire itself. On another note, it's not a good idea to mount a set of tires and immediately run them extremely hard as the lubricant used on the bead during the mounting process needs a little time to dry up.
thanks for the replies...as it turns out one front rim is ever so slightly bent and I acrually forgot about it(happened years ago) . Ive been living with it for years and because of the great balance this car has and the wheel balancing it never vibrated even over 160... But I guess when the rims/tires were out of balance it was noticable I just got a balance, so Ill see if that cures it for now until I can get another rim
