Wheel Studs & Lugnuts for C4
Old 08-26-2008, 11:52 AM
Rob 93ZR-1
Rob 93ZR-1's Avatar
Location: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Wheel Studs & Lugnuts for C4
I want to go with ARP, slightly longer than stock w/ open lugnuts. Anyone have correct part numbers. Running stock wheels for track day in the Z.
Old 08-26-2008, 11:57 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
I sell the studs on our website, and on our ebay store. The nuts I buy from the Auto parts across the street.
Randy
www.dougrippie.com
Old 08-26-2008, 01:32 PM
ScaryFast
ScaryFast's Avatar
Randy
www.dougrippie.com
What? You're not using racing lugnuts? How did you guys ever win races?
Old 08-26-2008, 02:28 PM
rasrboy
rasrboy's Avatar
Go with Randy @ DRM, They are 1" longer and hardened and are the correct size to press right in.
Have them on my C4 racer for over 10 years now with no problems.
Aaron
Old 08-26-2008, 10:03 PM
Lichen
Lichen's Avatar
Doofus question, but what is the purpose of longer wheel studs?
Old 08-26-2008, 11:07 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
got my studs at DRM and some Chevy nuts from a vendor here forgot which chevy dealer. Local guy was 110 for nuts and it seemed high. I think they were 55 here.
Old 08-27-2008, 09:17 AM
fmrfast
fmrfast's Avatar
Aaron
Same here ,over 8 years no problems at all. Talk to Randy
Old 08-27-2008, 10:08 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
The only stupid question in racing is one that isn't asked. The idea for the longer stud.
1. Use with spacers, which can change track, needed for brake caliper clearance, and etc
2. Easier to put on the lug nuts
3. can look at the open lug and see if anything looks different, vison torque all the time. I look at tires and wheels in the padock more then anything else.
4. These ARP studs are super strong also, which can be a life saver at the track.
Randy
To Wheel Studs & Lugnuts for C4
Quick Reply: Wheel Studs & Lugnuts for C4
