Custom Hardbar and new seats
Gary and I have been working together for the past month and a half on a custom design hardbar for the Mosler. The cockpit is very small and tight so the dimensions/design of the pieces had to be absolutely perfect. As you can see they came out great. The Teamtech harnesses are on the way, and the seats are Cobra Suzuka Technology (carbon fiber and Alcantara, which ended up matching the existing interior perfectly). Great job by Gary on the DESIGN, his SolidWorks modeling and the custom machining (and not bad on my part for gathering all the critical dimensions if I say so myself). The end result took several iterations with measurement verifications and dimension changes, and without Gary's design and modeling it would have been a difficult proposition. As Gary likes to say - you don't want to kludge something together on a project of this scope.
CF Senior Member
Very nice...good job! I've heard of Mosler's but don't know too much about them (I guess it's time to find out a bit more). Racing seats are looming on the horizon for my car as well.
1 Post
Cruise-In II Veteran
I am really glad it fit, the Solidworks/Haas CNC methodology is remarkable! We are working with a new anodize shop that can do the large C5 bars and from now on all Hardbars and seat rails (if requested) will be anodized (black) instead of powdercoated as they have been in the past. The anodizing does not add any measureable thickness and will not chip like powdercoated parts can/do. They did an awesome job on Everett's Mosler parts, they are really pretty in person.
1 Post
Thanks, but this was not really a "do it yourself" job. We exchanged the Solidworks models back and forth to get the dimensions correct using eDrawings. After the model dimensions were verified, it was analyzed using Cosmos FEA (static cases only) for the loading conditions such as fastener pull out, plate bending and strain distribution. After we were done with that the model was transfered to Mastercam for the CNC tool path for the end pieces, while the Hardbar was fabricated and lathe turned. When that was done, it was all sent to a state of the art anodize shop in MA. The seat rails were an adaptation of our C4 rails only with the custom mounting configuration that went through the same process as the Hardbar. All told, there was about $15K worth of software and work station, $250K worth of CNC machining tools, and at least that amount of anodizing equipment, not to mention 20+ years of aerospace mechanical engineering/structural dynamics experience!
By the way, is there a thread where I can see more pics of your Mosler?
Do you have the Hewland sequential transmission in your Mosler? I got to drive Corvette Mike's in Vegas during the Open Track Challenge with the sequential transmission. That car was a lot of fun.
When did you drive the car with the sequential - was it recently or some time ago? What motor - the LS6 or the LS7?
Jason from Katech will post info/details when the time draws near next year. I think the "alumni" get first invites, followed by some number of openings (not sure how many). It was a great event, great people, and a great track/facility.
Harnesses are in.
The harnesses are in, and I have been adjusting them to fit. They are Teamtech - Jet Pilot on driver side and RamPac 6 point on passenger side. The quality appears topnotch and I think I will be very happy with them. Thanks Gary!
Everett,
Holy cow! Now you've done it. Mods are like Jays Potato Chips, you can't stop after just one.
Last time I drove your car I thought how cool it would be to have a race seat set. You do understand that WE are going to have to check out those harnesses ASAP. WE need to make sure they are secure. WE are going to have to push the car a little harder this time! You're going to have to let me know how the passenger side holds up as WE drive it okay?
What led to the color choice of the Harness Bar? Were they out of Yellow?
Nice job Gary!
Mike
Nice job Gary!
Mike
Everett,
Nice job Gary!
Mike
Nice job Gary!
Mike
You are right regarding mods - you can't do just one.... the list for Jason is growing...
