Will C5 jacking pucks work on C6Z?
Old 10-20-2008, 02:22 PM
VettesRule
VettesRule's Avatar
Default Will C5 jacking pucks work on C6Z?
I will be racing this weekend with my new car but I haven't gotten underneath it yet.
Old 10-20-2008, 02:55 PM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
Don't know what kind of jacking pucks you have - fixed lug depth or adjustable ... the C6Z frame is slightly thicker ... I have made jacking puck sets, most recently with "eye" bolts screwed into hockey pucks ... they can be backed out slightly to fit snugly in a C6Z frame.
Old 10-20-2008, 06:45 PM
froggy47
froggy47's Avatar
Depends on what brand, the billet alum one I got are too thick in the "key" to fit c6, but some are "universal".
Old 10-20-2008, 07:54 PM
68sixspeed
68sixspeed's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
mine fit, but you just can't twist them to make them stay in.
Old 10-20-2008, 09:07 PM
Datawiz
Support Corvetteforum!
Datawiz's Avatar
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
You don't need the pucks if you're just using your own jack. Just make sure the contact point is on metal only. You can jack the entire side of the car from the front jacking point, enabling you to change both the front and the rear for one side.
I've done over 30 days of racing in my Z over the past year and have never used a puck.
Old 10-21-2008, 12:51 AM
VettesRule
VettesRule's Avatar
I checked it out tonight and I see what you guys are saying. I am going to turn the pucks on a lathe to increase the gap between the holding lug and the surface that makes contact. with the frame rail.
Thanks gang!
Old 10-21-2008, 05:39 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
c6z frame is thicker aluminum so they usually don't fit.
Old 10-21-2008, 12:06 PM
froggy47
froggy47's Avatar
Thanks gang!
That should work.
Old 10-21-2008, 02:44 PM
waktasz
waktasz's Avatar
Old 10-21-2008, 02:59 PM
Nimo
Nimo's Avatar
St. Jude Donor '08-'09-'10
As others have said - No, they don't fit. The neck is to short.
The benefit of having a puck that you can turn so that it stays in place, is that you don't risk pinching your fingers or stretching your back while holding the puck in place and jacking at the same time.
- Don't ask how I know
When changing tires often, I found that the BMW permanent pucks are very convenient. They snap in and stay on. Just need one in each front location.
Nik
Old 10-22-2008, 10:35 AM
FasterIsBetter
FasterIsBetter's Avatar
Ditto. I have the billet aluminum ones for my C5Z, and they wouldn't fit into the holes on my friend's C6Z.
Old 10-25-2008, 02:10 PM
Nimo
Nimo's Avatar
Originally Posted by sordfish
I just spent an hour putting my car up on blocks & looking under with a drop light & mirror at the lifting points both front & back & can’t find any slot to put my eye bolt hockey pucks in & be able to turn & lock then in. Are these slots on the 08 C6's.
There are two slots on each side - nothing up front or back. I lift using the sides or the cross members front/rear and a piece of wood.
- they are pretty much at the end of the doors. You should feel that the side skirt/piece is missing just around the slot.
/Nik
To Will C5 jacking pucks work on C6Z?
Quick Reply: Will C5 jacking pucks work on C6Z?
