Stock C5Z06 Wheels for the Track?
Old 10-21-2008, 03:27 PM
quick04Z06
Support Corvetteforum!
quick04Z06's Avatar
Default Stock C5Z06 Wheels for the Track?
I have a couple of sets of stock C5Z06 wheels from 03 and 04 cars. I was thinking of using the stock 18-inch rear wheels at all four corners of my '04 Z06 at the track. If I do, will the stock rear wheels fit on the front, what size/make tire should I run, and what other special adjustments or equipment would I need?
Thanks so much.
Old 10-21-2008, 04:23 PM
spazegun2213
spazegun2213's Avatar
people do it all the time. I think most people run 315/30 (or 35)/18's and are fine.
Old 10-21-2008, 04:36 PM
quick04Z06
quick04Z06's Avatar
Thanks--no spacers or adjustments needed? Great.
Old 10-21-2008, 05:55 PM
MJM
MJM's Avatar
Lots of people do it.
I have a 2000 FRC and have been running stock C5Z06 rear wheels on all four corners. Hoosiers 295 up front and 315 out back.
No spacers, no rubbing.
Old 10-21-2008, 06:53 PM
Fastguy
Fastguy's Avatar
St. Jude Donor '03-'05
I tried 315 V710's up front and they rubbed bad, the 295's look like they will fit.
Old 10-21-2008, 07:12 PM
NemesisC5
NemesisC5's Avatar
295/30's or 295/35's on the front?
Old 10-21-2008, 07:26 PM
MJM
MJM's Avatar
I think the 18 inch only comes in 30. The tires are in my trailer so I can't tell you for sure right now.
The wheels are the OEM speedlines 18 inch x 10.5 inch.
To Stock C5Z06 Wheels for the Track?
Quick Reply: Stock C5Z06 Wheels for the Track?
