Used DTC 70 Hawk Pads
Supporting Vendor
Well, we are down to the last few sets... All fit C5 or C6 ...
1. Rear DTC 70 Pads, C5,C6 50% Remaining. 2 set $35 per set. SOLD
2. Rear DTC 70 Pads C5 C6 60% remaining. 1 set $80 per set
3. Rear DTC 70 Pads C5 C6 65 % remaining 0 set $90 per set SOLD
4. Rear DTC 70 pads C5 C6 70 % 2 sets $100 SOLD
5, Rear DTC 70 75% 0 sets $110 SOLD
6. Rear DTC 70 95% 1 set $120 SOLD
FRONTS:
7, Front DTC 70 Pads, C5 C6 55% remaining 1 set $65 per set SOLD
8. Front DTC 70 Pads C5 C6 60 % Remaining 1 set $85 per set
9. Front DTC 70 Pads C5 C6 65% Renaining 1 Set $75 per set SOLD
10. Front DTC 70 Pads C5 C6 70 % remaining 1 set $85 SOLD
11. Rear DTC 70 pads 75% remaining 1 set $100 SOLD
12. Rear DTC 70 Pads 80% remaining 1 set $115
13 NEW Front Hawk DTC 70 Pads $235 per set.
14. NEW Rear Hawk DTC 70 Pads $225 per set.
Plus S & H
610-482-0141 jfaphoenix32@aol.com
FRONTS:
Plus S & H
On average, how much % of the pad is used up at a one-day HPDE? And at what % do the pads stop being effective (I'm assuming as they get thinner they'll transmit more heat into the calipers/pistons/fluid)?
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes
GOOD DEAL!!! OK guys, these pads are legit. I bought 2 sets a few months ago and must say they were as advertised, good shape, no taper, broken in correctly and had plenty of pad left to serve me well in HPDE's. I liked the fact that I did not have to worry about glazing the rotor from a new pad. You need a pad, you give 'em a call........
