Difference in C5 LCA and C6 LCA?
It seems that when the C6 first came out I read some place that the C6 LCA was dimentionally the same as the C5 except it was a little longer.
Does anyone know if this is correct and how much longer?
The reason I am asking is I have a 69 Camaro running C5 front suspension. I am limited to 1.5 max on my camber setting and a longer arm would help this situation.
Received 8,927 Likes
If I let caster stay where ever it falls when I adjust for max camber I can get -2.2 to -2.3 degrees on a C5.
Bill
They are mounted in the same position
and I am using the eccentrics on the bottom. I need to take it down the the alignment shop and crank them over and get a true reading.
I have friend running a 69 Camaro using C6 stuff. He can run as much as 3.5 of Camber with his set up. He had to go that much to get an even temp across his R888's at the track.
I have done a few auto crosses in my car and plan on a few HPDE this spring. I am trying to get the car set this winter. I know it seems strange I am posting here, but running C5 stuff up front, LS1/T56 and a car weight that is close. I figured this is the best spot for info.
Thanks for your help
There are no shims in the UCA
It does however have pucs that I can raise or lower the positon of the UCA...which if I lower would increase my camber gain.
Stock C5 gain is .60 per 1 inch of travel?
What bushings do you run? The standard upper ca mount has the pin through the middle with no difference if you mount them with the pins rotated one way or another. You can get the poly bushings with the offset bars for more camber
I saw the poly bushings with the offset shaft
My experience with poly bushings is they bind and squeak. Are the ones offered now better?
Looked at the spherical busings as well but thought that they would be too harsh on the street. Do you know of anyone running these that could comment?
