C6Z Setup For SS
C6Z Setup For SS
After reading the Super Stock C6Z versus C5Z tread it sounds like there may be more C6Zs show up for 2009 nationals. I'm looking for discussion on set up for C6Z such as alignment, shocks, front sway bar, ride height, tire sizes, etc. to name a few, that some of you C6Z drivers have tried. Remember this is for autocrossing (solo 2) type events not track events.
Of course, this is what I'm looking at. Those competing successfully can chime in with their setups, and save us some money by telling us what DOESN'T work!
Former Vendor
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
Pfadt SS Package
We have been working on a SS Package for the C5, C6 and C6 Z06. We have developed a SS specific front sway bar package that gives you at adjustable sway bar that is matched to your specific factory rear sway bar.
We have also been having great success with our Sport Shocks in Super Stock. The Sport Shocks feature simple damping adjustability that allow you to change the corner entry and corner exit balance of the car. They also feature an inverted design that reduces the unsprung mass of your suspension, this allows the suspension to react to the road surface more effectively which gives you better traction!
See what one of our customers had to say about the SS Package...
Click Image
Please let me know if there is anything that I can help with!
Click Image
Click Image
Click Image
Thanks for your input. I look forward to developing my car at some point, and I'm open to all suggestions.
After Chris Ramey sold his 07 Z06, I bought the wheels and tires he was running on the car. He had Hoosier's A6 with the 315/18 on the front and the 325/19 on the back because he felt the car was pushing too much. Since then I ran this wheel and tire combination on my 07 Z at several events and found my car was fairly neutral with the factory alignment. I checked the alignment from the factory my car had -1.5 in the front with -.09 in the rear for camber with +1/8" toe in the front and back. I plan to do a much more aggressive alignment on the car this spring and then I'll see what the car does.
My plans are to increase the front between 2 to 2 1/2 neg. and the rear may go to 1.2 neg. I plan to put in 1/8" toe out in front and leave the 1/8" toe in on the rear. I'm thinking this is going to increase more oversteer and to off set that I'll want to switch to the 345/19 on the rear. I also have my Koni's to put on. Running on concrete hopefully I can put that 505 hp to use.
Most vette drivers run tow-in in the rear to reduce the ovesteer on powerdown corner exit. When the car squats upon power accelleration it actually toes out a little, so the static toe-in counters this change upon powerdown exit.
But still, you may be on to something with the C6. Only testing will help find out the answers. So far using the C5 tuning tricks on the C6 haven't been found to help it all that much. Good luck.
I've installed the Pfadt hardware Josh is decribing. I've only done one event with this setup (using 295/18 and 345/19 Hoosier A6s). I felt like I wasn't pushing the car enough, though I did fine from a competitive standpoint. There is more capability in the car now, and I need to explore it more. Maybe I need to drive it a little differently; I'm a recovering C5 Z06 driver.
One dilemma is finding the right setting on the Pfadt adjustable front bar, so the car turns in and avoids mid-corner understeer but is simultaneously planted when you put the power down coming out. I'm going to try "one more hole" on one side and see what happens. I'll also try some more toe out up front. And playing with the shock settings: softening the fronts seemed to help in the one chance I'd had to run the car with all this stuff on it.
I'm skeptical that there is any gain to be had from downsizing the rear tires from the 345s. Losing grip at one end to help the other end is sub-optimal at best. Plus there isn't that much steady state cornering in autox.
I had not thought of trying 315s on the front. 315s would raise the front a third of an inch. Not much. I assume the 315s fit?
The 315/18 fit on the front of a C6Z with stock oem rim sizes just fine.
Here is a tread on the SCCAForums.com you might be interested in reading. It pertains to setup of C5Z for SS.
http://sccaforums.com/forums/thread/334487.aspx
Understeer : The tendency of the front of the car to "push" when negotiating a corner (car wants to go straight)
Oversteer : The tendency for the back end of the car wanting to come around (car wants to spin)
Neutral : The car neither oversteers or understeers
Most cars are designed from the factory to understeer, as it's safer for the general public. If you go into a corner too fast, the first reaction is to usually hit the brakes. If it's a car that oversteers, hitting the brakes (usually) will bring the tail around and spin the car. Not usually considered a good thing. If it a car that understeers, hitting the brakes will generally slow the car and allow it to negotiate the corner.
High Performance Handling Chart
To Decrease...........To Decrease
Understeer..............Oversteer....... ....Adjustment
Higher.....................Lower........ ......Front Tire Pressure
Lower.....................Higher........ ......Rear Tire Pressure
Larger....................Smaller....... ......Front Tire Section
Smaller...................Larger........ ......Rear Tire Section
More Negative.........More Positive......Front Wheel Camber
More Positive..........More Negative.....Rear Wheel Camber
Toe-out.................Toe-in...............Front Toe
Toe-out.................Toe-in...............Rear Toe
More Positive..........More Negative.....Front Caster
Soften...................Stiffen........ ......Front Springs
Stiffen...................Soften........ ......Rear Springs
Smaller..................Larger......... ......Front Anti-sway bar
Larger...................Smaller........ ......Rear Anti-sway bar
That's a great summary chart. And it makes me wonder how much caster adjustment we have for our cars (C6 Z06). I have not tried to maximize it, but maybe I should. Would it make much difference? (???)
As for the SCCA Forum thread, yes, I saw it, and these guys have pretty much written off the C6 Z for autox. It is informative, though.
Toe-out in the rear will help the car rotate on the turns, but it can make a rear wheel drive car squirly when you put the power down. FWIW.
Hard to say where you'll really end up on a C6Z though. It has the big wheel offset which suggests you might want less toe-in or even a little toe-out, but then it has that big rear bar also. Just have to test and see what works.
Dave G.
wow, i didnt know 315s fit on the front...i always thought 295s were the biggest size one could run on the C6 Z06 in stock trim...
anyone else using this combo??? if it works, i'll switch to that next season...
i just installed my pfadt shocks and front swaybar...next race is in 2 weeks, so we shall see how much i'll need to adjust my driving...
One thing I have not seen mentioned, is the difference 1 or 2 drivers, in the same car & class can make. As one can see from the results for years at events, 2 driver cars have a big advantage. So when setting up the car does one tune it for moderate tire temps or optimun tire temps. Where I'm located, we can go from 40's in the a.m. to 80's in the p.m. The 2 driver setup helps to even out the tire temps, getting them up there faster and maintaining them. This can change how the car is setup. Othe ideas?
Ted the 315/18 were on oem C6Z polished wheels and I have made at least 30 runs on them with my 07Z with a lowered ride height and I have not had any problems with the front rubbing.
