Dynatech tells me I am the only one
Old 12-11-2008, 06:07 PM
varkwso
varkwso's Avatar
Default Dynatech tells me I am the only one
As some may remember I had my driver side Dynatech header blow off the air tube at Roebling in May. Dynatech sold me a new driver side header and then when I shipped the old one back (in the return freight box provided) they reimbursed me the price of the header.
Sunday going under the bridge at T11 of Road Atlanta the passenger side blew off. When I talked to Don at Dynatech today he told me I was the only one to ever lose an air tube off of one of their headers and now that I had a second one so it must be something I am doing wrong. He did asked me if I "raced it".
"Greg" from Dynatech will be calling me on Monday to see what they can do this time when he gets back from the PRI.
Am I the only Dynatech C5/6 customer to lose air tubes off their header?
Old 12-11-2008, 06:46 PM
Rob's 73
Rob's 73's Avatar
Are you running CATS? I had an air line and check valve blow when my CAT failed and clogged the exhaust. This happened while on track. It also happened to another CF HPDE'r. He lost his brakes because it either knocked or burned off the vacuum boost tube.
If you are running CATs check them while you have the header off. I think the aftermarket highflow CATs fail much more frequently than the stockers. I'll never run them on the track again.
Old 12-11-2008, 07:14 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
just weld the holes shut.........
Old 12-11-2008, 07:17 PM
lbarnard
lbarnard's Avatar
Happened to my LG Long Tube headers at RA last week. And the time before big PIA; Like DF said weld hole and all will be fine!
Old 12-11-2008, 07:42 PM
varkwso
varkwso's Avatar
Cats are fine...
I already thought about welding the hole...
Old 12-11-2008, 08:09 PM
mountainbiker2
mountainbiker2's Avatar
I have Kooks and one cracked on me.
Old 12-11-2008, 08:53 PM
Pontiaker
Pontiaker's Avatar
My Dynotechs have been great so far, did 12 events this last year.
Matt
Old 12-11-2008, 08:59 PM
wallyman424
wallyman424's Avatar
Chinese ebay headers 1 year strong!
Old 12-11-2008, 09:13 PM
davidfarmer
the newer cars don't even have AIR. I just whack them off and weld them shut
I can't keep an engine in my current NASA car to see if the headers will hold up (although LG's never let me down before)
Old 12-11-2008, 11:36 PM
coffey
coffey's Avatar
All the LGs that we ran did that.
Old 12-12-2008, 05:56 AM
varkwso
varkwso's Avatar
Think I can do it with the header still attached to the car?
Cuccharia - I probably have 85-100 events on these headers. I have this addiction problem....
Old 12-12-2008, 05:58 AM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Both sides of my friend's Dynatechs air tubes blew off too. Taaz024 here on the board.
Old 12-12-2008, 11:43 AM
Joy of 6
Joy of 6's Avatar
My right side blew off and I had a plate made to cover it and weld it shut. I had the AIR system removed when I did a head/cam swap. when I get aroudn to it I will take off the drivers side and weld it shut too.
Old 12-12-2008, 11:46 AM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
both of mine too!
welded them up no more issues
Johnny
life is good
Old 12-12-2008, 01:44 PM
lbarnard
lbarnard's Avatar
The weld can be done while the header is still on the car. May not be pretty but it is possible. I had mine welded at Road Atlanta with them in the car.
Old 12-12-2008, 04:02 PM
varkwso
varkwso's Avatar
a whole lot less work then pulling the header....
Old 12-12-2008, 07:26 PM
clockworks
clockworks's Avatar
What the heck are yall talking about? I just installed LG Pros and enjoy going to HPDE's, should I be concerned?
To Dynatech tells me I am the only one
Old 12-12-2008, 08:27 PM
sothpaw2
sothpaw2's Avatar
Is the car still emission legal with the AIR tubes gone? Will it throw codes? Who did your welding--someone at the track?
If one gets stranded with this failure at the end of the last session of the day, can one limp the car home with the tube blown out? Or do you have to gerry-rig something?
Thanks for posting, this is very informative. I have the Dynatechs w/aftermarket cats but have had no issues at all in 11 days (8 events).
Old 12-12-2008, 08:30 PM
lbarnard
lbarnard's Avatar
LG's headers are good. Eventually you may have an issue until then don't worry.
Old 12-12-2008, 08:38 PM
lbarnard
lbarnard's Avatar
A shop next to Road Atlanta did the welding. We cleaned the area and welded the hole with a washer to fill the hole and filled in around that until there were no leaks. If you have that AIR blow out while on the track you will hear it. A very loud ticking. I would not recommend you continue to drive the car unless you can fix the hole in your header. I did try one time to gerry rig but the header pressure blew out everything I tried. No codes at all. Just a loud ticking! Could you drive the car home with a gerry rig? I don't think so. No problem with emission if you plug that hole!
Quick Reply: Dynatech tells me I am the only one
