Adjustable Koni Shock & Bar Special
Premium Supporting Vendor
Year End Savings….
• Instant Improvement In Handling
• Inverted Design
• Single Rebound Adjustor
• Danny Popp inspired Valve ing
• Sway Bar Complete with Adjustable Heim Joint End Links
• Polyurethane Frame Mount Bushing.
This C5/6 Shock and sway bar package is inspired by multi time national champion Danny Popp. Working with Danny, Koni, and ADDCO this package delivers performance and ride. Inverted for weights saving, the valving is the results Danny and Van Steel perfecting the handling of a Corvette using the composite spring suspension.
Installs at home in an afternoon.
We are offering Koni Inverted 3013 shocks plus a Tubular 35mm Front Sway Bar and a Tubular 25mm Rear Sway Bar for 20% off. Cost of the whole kit is only $1399.99. A total saving of $430.00
If you want to add Front and Rear Hyperco Composite springs, any rate, the price is $2299.99. A total savings of $573.00
Please contact Paul Lesinski or Dan Dorsett
800-418-5397
• Inverted Design
800-418-5397
