335 back tires
Old 12-14-2008, 09:57 PM
michaelkrelina
michaelkrelina's Avatar
Default 335 back tires
Is it necessary to widen the wheel wells on a C5?
I intend to use wide tires for track and autocross only and don't mind if they protrude. The car has been lowered only minimally and is still within factory specification limits.
With a stiff set of sway bars such as T1 or Pfatty Bars will a protruding wheel rub against the fender in a turn? The springs are stock at this time.
Mike
Old 12-14-2008, 10:00 PM
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
mine rubs when loaded down or if I hit a bump pretty good...otherwise no...so IMO you would have issues on Auto X...how bad? I dunno...
Quick Reply: 335 back tires
