New T1 Rule; Edjumicate Me on C5 vs C6 OEM Calipers/Pads
Some 17" wheels have more clearance than others so if someone states their 17" wheels clear yours may not. Might be time to move up to 18"
Supporting Vendor
The C6 Z51 rear calipers have smaller pistons than the C5 and C6 base do so I would rule that out. On the smaller rotor you will lose some brake torque.
Fronts and rear/C6 base rear should all be the same aside from caliper structure although idk if they fit each others brackets.
C6 Base front rotors at least from GM went to a heavier rotor that uses pillar vanes and more mass. (C5 front rotors are curved vane)
