Watch as the Vettes take out the Ferraris and Vipers.. live timing T1
#42
#44
1 Post
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
There are options, I'm pretty sure some people spent more on Run Offs than I've spent on my entire season including a trip to Road Atlanta & Miller Motor Sports Park
#45
30 crew guys.
10 engines.
Unlimited tire budget.
Unlimited test track time.
The list was significant.
#47
1 Post
Yeah, I was talking some of about the cars that didn't win, I'm guessing that 430 team spent more to run the Run Offs than I spent the entire season + what I paid for my car and that's not including their car.
#49
1 Post
That F430 in T1 is a joke, talk about buying a trophy. You can give a corvette all the brakes you want and they still will have no chance against an equal driver in a F430.
#50
I did notice ST won the F430 Challenge in 2009 (or is leading it). That's a $24,000 entry fee for four races -- but it includes tires. Each additional race is another $3500.
#51
2009 Ferrari F430
Price Range:$187,925
2009 F430 Challenge
Base Price $282,618
or there about
But then again DEEPEST pockets put that car at the pointie end of the field
Driving Skill, and ST is a very good driver right to that that tip.
2009 F430 Challenge
Base Price $282,618
or there about
#52
To win an amateur race.
#55
The T1 times are closer to the GT2 times. Best lap time of that race was 2:20.841. That's marginally better than what ST ran in the 430 for qualifying. Crazy times the T1 class is running now. Last year a 2:24 would have sufficed. Now we have drivers pushing equipment harder thus taking much higher risks trying to keep pace and still falling short. Nobody has really discussed it, but there were plenty of incidents during qualifying week that made the field smaller.
#56
Wow, I didn't even realize that
#57
30 cans of beer
10 jello shots
Unlimited burgers and brats
Unlimited time spent talking about racing
I guess I could have had a shot at a podium.
#58
One of the highlights of the week was my dad and I having dinner with Jerry Onks, his wife and Chris Brannon (AS guy) at Siebkens throwing some beers back and making fun of the Ferrari team and how much money they are spending to beat us.
#60
Sent previously this year (early) to the CRB.......
To whom it may concern:
Please consider allowing an aftermarket caliper/rotor for the T1 Corvette. The PBR two piston caliper is inadequate at best and was never designed to withstand the rigors of racing. History shows repeated caliper failures resulting in damaged rotors which in turn present a major safety issue for any Corvette driver. These parts are ‘must replace’ frequently items and as they begin to fail (spread), cause overheating and cracking of the rotors due to maximum clamping force on a very small amount of rotor surface. I believe this is why the Corvettes see so many cracked rotors after just a bedding session and a single race.
Upgrading the C5 using OEM parts is cost prohibitive. The two possible upgrades available are the Z51 and Z06 brake systems. Both upgrades have larger rotor diameters therefore forcing all C5 drivers to purchase new wheels to clear either kit. Most racers use a minimum of three sets of wheels (two sets of dry and one set of wets mounted at all times). Replacing these three sets of wheels with new 18” units would run at minimum $7500 not including the cost of the brake upgrades themselves.
I have researched Wilwood calipers for the Corvette and have been advised by their technicians that the correct caliper for this car based on master cylinder / rotor size would be one of their six piston units which also utilize the stock C5 and C6 rotor (non-Z51) along with the stock master cylinder. This change in caliper design will allow for a much more even clamping force on rotors and possibly eliminate the broken rotor syndrome experienced with ‘push/pull’ calipers like the PBR unit. Wilwood also offered a wider 6 piston caliper that uses a two piece hat/1.25” rotor combination. This combination also uses the existing 17” wheels on the C5 and allows the C6 to run the smaller wheel combination also. This larger kit would virtually eliminate any brake failures due to use ‘other than intended’ on a race car.
The Wilwood kits are bolt on and come with brackets, lines, pads and mounting hardware. The caliper only kit retails for $1410 while the larger caliper and rotor kit retails for $1965. Again, neither requires the purchase of new wheels.
My request is to allow the front calipers on the Corvette to be open and to allow any rotor or rotor/hat combination that doesn’t exceed the original equipment diameter (allows for a thicker rotor if desired). Master cylinder must remain stock. Rotors must be of original composition.
Although allowed, our team doesn’t run the $4000 – $10,000 shocks that have been granted to the class, however, we would gladly spend the money to upgrade our brakes for the safety of our driver.
The pictures below depict the problems associated with the two piston PBR caliper, whether used on the Corvette, or the Mustang in T2/3. It’s virtually the same unit with the same characteristics.
If you would like to hear more from other T1 (and non-T1) drivers on the subject, please read:
http://sccaforums.com/forums/thread/282276.aspx
Sincerely,
Steven Glaab
SCCA T1 #5 Crew Chief
Natha Waldbaum, Driver
Sincerely,
Steven Glaab
