Will worn parts cause more wheel hop?
Old 10-26-2009, 11:34 AM
Maxx Schlick
Maxx Schlick's Avatar
Default Will worn parts cause more wheel hop?
When my car was new it got zero wheel hop. Even with hard burn outs, it got zero wheel hop, not even a litle bit. It could spin the tires slow, it could spin the tires fast. I could roll the gas on smoothly, or I could just stomp it. No mater how I gassed it, there was never any wheel hop at all.
It now has 18k on the clock with lots of track laps and lots of drag launches. Now it gets uncontrolable wheel hop the instant the wheels start to spin. No matter how smoothly I roll into the power, the instant the tires loose traction, the hop starts. Even in the rain where it takes very little gas to spin the tires, they will not spin without getting violent wheel hop.
I have 4 sets of tires and wheels right now.
Michelin ZPressure
Bridgestone RFlats
2 sets of Hoosier r compound
Each tire gets the hop with the slightest amount of spin.
FWIW
The right tire is the pogo stick, never noticed the left one bouncing at all.
I'm thinking it has to be worn parts. Shocks, tranny mounts, bushings ?
My question is, are the shocks the most likely part to contribute to bad wheel hop?
Old 10-26-2009, 11:44 AM
froggy47
froggy47's Avatar
Tires? Then/now.
Old 10-26-2009, 12:40 PM
AU N EGL
AU N EGL's Avatar
Originally Posted by froggy47
Tires? Then/now.
Heat cycles ?
Bushings need to be replaced.
Check your shocks and springs.
parts wear out.
Old 10-26-2009, 01:13 PM
95jersey
95jersey's Avatar
My OEM goodyears were great when new, but after a couple years and just 5000 miles, I could spin them at will.
I put on some new exclaims (street tires) and it was like glue again. If they are new tires, I would think shocks second.
Old 10-26-2009, 01:22 PM
Maxx Schlick
Tires? Then/now.
Michelin ZPressure
Bridgestone RFlats
FWIW
Old 10-26-2009, 01:26 PM
Maxx Schlick
Originally Posted by AU N EGL
Heat cycles ?
parts wear out.
How do you "check" the shocks and springs?
Old 10-26-2009, 03:18 PM
Solofast
Solofast's Avatar
Default Bushings and shocks
Bushings and shocks are the two biggest variables here (assuming tires which is the biggest variable are comparable).
Bushings allow compliance and compliance leads to the windup and hopping...
I'm getting hop with my Koni's on certain settings, so if you have worn shocks it's easy to see how that would lead to hop.
Old 10-26-2009, 04:39 PM
dfinke23
Support Corvetteforum!
dfinke23's Avatar
Have you watched from outside the car to see the right hopping more than the left?
Old 10-26-2009, 06:48 PM
Maxx Schlick
have not seen it from outside , but from the drivers seat it is pretty obvious. You can feel and hear it.
Old 10-26-2009, 07:48 PM
davidfarmer
davidfarmer's Avatar
should would do it definitely, bushings possibly. Pull that shock. You should barely be able to move it with your body weight. I've had bad/blows shocks that were virtually frictionless........
Old 10-26-2009, 08:37 PM
dfinke23
dfinke23's Avatar
Is it possible that it is the tranny mounts?
Old 10-27-2009, 12:44 AM
Maxx Schlick
Looks like the answer is absoluty yes, that is what was causing it for forum member Isaiah48
along with broken motor mounts.
To Will worn parts cause more wheel hop?
Quick Reply: Will worn parts cause more wheel hop?
