Tranny question??
Old 10-27-2009, 07:00 PM
shifter77
shifter77's Avatar
Default Tranny question??
Ive got an RPM stage 5 tranny about a year now. Just changed fluids in tranny & diff. For the last month or so ive been noticing that the shifts are notchy. Not as smooth. Had the shift linkage adjusted aswell. Ive called RPM, they said i could be the clutch. I really dont know at this point.
Any sugestions.
Old 10-28-2009, 07:44 AM
ipuig
ipuig's Avatar
St. Jude Donor '09
This seems to be a recurring theme with these transmissions. There is an individual reporting the same problem in the C-5 tech section. A representative from RPM has posted recently stating he would help the OP troubleshoot his problem. You may want to take a look at it to see what the resolution, or lack of it is.
Old 10-28-2009, 08:06 AM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
is it grinding, or just hard(er) from gear to gear?
is it consistent from 1-6? (ie, did they all start getting worse at the same time?)
Old 10-28-2009, 08:41 AM
AlwaysInBoost
AlwaysInBoost's Avatar
what type of fluid are you running?
I noticed a positive difference in shifting feel when I switched from Royal Purple SYNCROMAX ATF to Redline D4 ATF.
Old 10-28-2009, 08:46 AM
AU N EGL
AU N EGL's Avatar
How many times have you changed the trans fluid since you got this trans?
and a great synthetic trans fluid does wonders.
I change my fluid every 4 track weekends and have a trans cooler.
Old 10-28-2009, 03:25 PM
AtomicZ
AtomicZ's Avatar
My RPM Stage 5 was just sent back. Lost 5th gear completely and it is hard to shift into 4th gear.
Running Redline and change fluid every 4 track days.
Old 10-28-2009, 09:59 PM
shifter77
shifter77's Avatar
Ive had the oil changed 4x with synchromax. Seems that 2nd gear is the problem. Pops out of gear on downshift + not smooth shift into 2nd.
Will have to inspect tranny and take it from there. Will post solution.
Thanks to all your input & help. Rpm has been very helpfull aswell.
Old 10-29-2009, 01:20 PM
4wheels
4wheels's Avatar
Sounds like you've got more than a fluid problem... either shift linkage or internals. These things are picky on fluids though. Redline D4 has the best overall shift feel for a readily available oil, but I found like many other ATF's, it get's notchy at extremely high temps that you might see in a long road race session if you're using the factory trans cooler (my exp is with a C6Z tho).
Old 10-29-2009, 02:52 PM
sgsvette
sgsvette's Avatar
RS: have you tried going to the $5 car wash? It might not fix your problem, but you could leave there with a clean car.
Old 10-30-2009, 10:04 AM
shifter77
shifter77's Avatar
SGSVETTE.
To Tranny question??
Quick Reply: Tranny question??
