Harness Tech Question
I have the Crow 6 point harnesses in my car. I wasn't allowed to use them per the tech guys until I had racing seats so the belts could go through the seats. I just installed Corbeau FX1 Pros. My question is now that the belts go through the seats, do I have to still find a way to secure them to the roll bar behind the seats? As is, they can slide a small bit back and forth, but since they go through the seats they will not slide off my shoulders which was the issue with the stock seats.
I just don't feel like going to tech the car and getting turned away. I thought about welding a small loop on the rollbar just to keep them in place.
Also, I mounted the subbelt anchors to the rear floor frame by where the seat mounts. I am not using my stock belts when these seats are in, so I mounted the lap belt to or near the stock belt mounting points on the Corbeau seat brackets. Seems to work well but wanted to see what you guys thought.
Thanks!
Thanks!
I run the FX1 Pro and Crow belts set up just the way yours are and I have never been faulted by tech for not having the belts captured laterally. Go for it.
St. Jude Donor '10-'11
Best thing I've seen for locating the belts on the bar is a two-piece nylon/metal ring that screws around the bar - use to keep the belts from sliding - can't remember the vendor tho ...
EDIT: Here it is ... thanks to FatBillyBob @ post # 12:
http://forums.corvetteforum.com/auto...-question.html
Thanks guys. Those shaft collars might not be a bad investment just to be sure and was actually what I was thinking of but wasn't sure where to get them. The only thing so far I am not happy with is the angle of my seats. I am going to have to pull them and readjust, tilting them more.
One thing to watch for is the groups wanting a seat back brace... this is my favorite: http://www.ioportracing.com/Merchant...tegory_Code=IH
Easy to adjust, easy to add.
Another cheap option is to zip tie a small piece (ie 3-4 inches wide) of roll bar padding onto either side of where you have the belts attached to the rollbar. The stuff I am referring to is the softer stuff, not the high density type (but either one will work). I did this with the setup in my previous car and did not have any issues with the harnesses moving around.
