Mark current toe settings
I just had my car aligned for autocrossing and now want to experiment with adding more toe-out in the front.
What is the best way to mark the threads so I can get back to where it is now? To get toe out I'll be shortening the arms so the turnbuckles will be going over the threads and would strip off paint, wont they?
Thanks!!
Thanks!!
better just to count the "flats" and write them down.
Also, learn to actually measure the toe so that you can double check it occasionally.
**to get toe out in the front, you lengthen the arms, but you'll have to loosen the jam nut which would damage any writing as you suggest*** The rear is opposite
Ideally, where should you measure the toe? Is it good enough to come straight down from where the rim meets the tire?
If I was to make my own toe plates, where do they typically measure the toe from? Is it from the edge of the tire?
Lastly, how do toe plates get around the tire bulge at the bottom of the tire?
Buy a set of Longacre plates and you'll see...it's easy. You'll run one measuring tape in front and one behind the tires. If the measurement on the front tape is shorter, then you have toe in, etc. It's no sweat!
I mark the tie rod and end with a paint pen. I have 3 colors on them for different settings.
I reset my rear toe after every autox because I run a good amount and try to limit tire wear.
Kudos to you for trying different settings. Everybody likes something different!
I am really asking since I want to make my own. I manually am checking the toe where the rim meets the tire and running tape measures.
I either measure on the grooves of the tire (if there are grooves) from side to side using the same groove front and back (down low enough that the tape will stay in place for one-person measurements) or I'll measure on the outside sidewall edge of the tire if I have my gauge with me. The gauge is just a couple of uprights and a piece of EMT that is placed against the tire or rim and then the measurement is taken between the uprights.
Again, I'm only looking for relative distance when setting toe. It doesn't matter to me if it's actually exactly 1/32" or 1/16" (let alone tenth of a degree) as long as it's repeatable. I change it so often between race and street settings that precision is an illusion.
As Dave says, count the flats. From where I measure, I've found a flat to be equal to about 1/32" per side. So, turning one flat on each side gives 1/16" of toe change. It will get you close enough to win the big money we're racing for in autox and HPDE and also give you great tire wear.
The plates I've seen are just L's that can be made. To allow for the tire bulge they just have a section in the middle cut out at the bottom that will span the tire at bottom center. An opening of 6-8 inches wide should be enough with 2-3 inches in height to clear.
--Dan
there is a ripoff copy of Longacre plates on Ébay, although they don't include tapes. $35 delivered Unless you have aluminum and a brake already, I don't think you can make them that cheaply.
I'm fine with my $6 setup (straight edge and tape).
hey, and just a quick note, I use 3 "flats" = 1/16". In my experience, a flat isn't quite 1/32"
Does anyone know what size thread is on the tie rod? Is it metric like most other hardware?
I actually measured 0.070" with 1 rev of the tie rod. I mounted an 0.001" dial indicator on the edge of the rotor (tire was off). Based on 0.070" of measurement, it looks to me that it might be a M12 x 1.75 mm pitch which works out to 0.069".
M12 sounds right, as you use a 13mm wrench to turn them, but I've never checked? Are you planning on making your own tie rod ends also, or are you just trying to calculate the exact change "per flat"?
As we've each posted numbers of flats to count to give a toe change and have different results I'll ask a question or two along with my understanding of this. The toe measurement in inches will vary depending on how far out from the axle centerline it's measured, correct?
For instance, if I measure at the base of the tire which is maybe 4-5" out from center vs. at the rim (8-10") vs. on the tire (12-14") the toe will be greater in inches the farther out one goes. If that's the case then the number of flats has to correspond to that point of measurement and will vary if not.
I'm thinking that the flats method will always yield a set number of degrees of toe regardless of how far from centerline. Is that right?
Thanks for any insight you (or anyone else can offer.)
--Dan
Dan, you are correct. I measure at the rim edge. I'd got out even further, but I feel the tire shape can become inconsistent once you leave the rim. I measure camber the same way so that I have a consistent set of numbers I can easily remember.
1/32" = 0.1deg (for toe measurement) .....which works out to 1" = 3deg (for camber measurement with tape-level) when my camber gauge isn't handy
YOU should absolutely come up with a system that works for you, AND that you don't have to relearn every time you do it.
--Dan
Premium Supporting Vendor
I agree. These are very easy to use and pretty inexpensive (about $60 last time I looked). Definitely a better option than marking and not knowing exactly what you have - even if you count flats on the tie rod.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
